99 ES300 oil leak passenger side
I've got a slow but steady leak onto floor below on the passenger side (results in maybe a couple teaspoons of oil per day) . I suspect it's the cam and crank seals because it seems to be originating behind the timing belt cover.
But what do you guys think based on the pics below? It's not the VCG 'cause those were replaced a few months ago and I verified they're pretty dry and clean today.
Also, a secondary issue is that the "boot" (? I'm not sure if that's what you call it) below the pulley in the 2nd pic is cracked and is leaking grease. How does one fix this? Is it expensive? I will have to pay a mechanic it's beyond my ability.
Thanks in advance for any insight.
Could be the oil pressure sending unit it's above the harmonic balancer they tend to fail and leak. That looks like an aftermarket axle or maybe the OE axle with aftermarket boot. If that's a Toyota axle then get your mechanic to only replace the boots.
I don't think it's the oil pressure switch. But any thoughts or ideas are welcome. I bought this car new in 1999 so the axle must be original Toyota. Maybe I had the boot replaced years ago with an aftermarket - I don't remember.
Picture taken from underneath the car.
It's a fools errand to try and pinpoint leaks, as you drive air blows oil all over the place. Wash the engine, start it and watch that area. If you have original axles don't toss them they are 10x better than anything aftermarket.
That #2 drip looks like hydraulic/atf and not oil. Is it from the pump?
Also, re: boot. IIRC, that’s the long axle side, harder to remove, and more likely to tear the inner seal. I know it’s frowned upon, but that looks like a great place to try this UK-made split boot. I tried one not long ago and it is well-made. It’s a relatively easy job.
This is UK made, instructions are clear and complete on how to do it correctly. They are not good for tri-lobed cans on the large end, but that one is circular and it should work well:
It’s also cheap and quick enough to try and not cry if it doesn’t last forever. As I said, I used one and was reasonably confident it was quality and likely to be worth it.
Ok. I am getting some UV dye and will see what happens.
TRQ videos may be fine; don’t buy their parts. I purchased a “new” axle for a different car recently, TRQ. It arrived and was clearly used and merely cleaned and re-booted. The outboard CV joint was seized (would not freely rotate). I popped the inboard carrier bearing cover off, and there was barely any grease in the sealed bearing. It was trash, right out of the box.
Make certain. I have seen it not done. IME, the tensioners have failed more often than belts (1 vs 0). When the tensioner fails, the valve train loses time, of course, same as if the belt snapped in two.
UPDATE. I took the timing belt cover off. The timing belt area looks pretty clean . Should there be oil in there if the cam seals and crank seals were leaking?
I put UV dye in the oil and I clearly see a leak from where the front valve cover meets the timing belt (see pic) . Do you think it could be the valve cover gasket? I did it 6mos ago, but maybe I didn't RTV well enough in the little corners. Also, I used Fel-Pro. Maybe that was a mistake.
Pictures under UV light:
There's also some oil below the timing belt. I'm thinking it's the same source above, but gravity pulls it down.
