Parts check request
Parts check request
So it's time to replace the front and rear brakes/rotors on my 2012 IS250 AWD non sport suspension up in Canada. After perusing the forum, it appears there are different sizes and thickness of rotors, and what you need depends on the model/year/spec/US or CDN spec? Just want to double check with the forum. It appears I need Rotors that are 11.5" in diameter, with the fronts being 32mm thick.
I plan on getting from Rockauto :
Front Right L: Centric 12044139 Semi coated rotor
Front Left: Centric 12044140 Semi coated rotor
Rear :Centric 12044142 semi coated rotor
Front pads : AKEBONO ACT908B
Rear pads :AKEBONO ACT1113
Better suggestions/advice are welcomed! Thanks!
tangcoral
15
06-05-08 12:56 AM
rclab1
09-01-06 11:47 AM
