compressor bearing pulley noise
2002 sc430 w/ 292,000 miles. I'm going to replace the bearing myself. What is the bearing part number? (I believe its NSK 35BD5222DUM18A, which is interchangeable with KOYO DAC355222). How do you get the 10mm bolt off? There is nothing to hold on to as you turn that bolt. I'm also guessing that you need a bearing puller to get the AC pulley off once that bolt is removed. And then a bearing press to get the old bearing out and then to push the new bearing back in. Am I missing anything?
Check out this thread
https://www.toyotanation.com/threads...n-car.1399785/
Probably the same basic procedure on your compressor. I'll let someone else answer the bearing part number question.
blkstealthpaid4
10-30-23 06:54 AM
