Does the sc400 timing belt tensioner bolt into the block?
Old Yesterday, 05:33 PM
Kxdza
Kxdza's Avatar
Default Does the sc400 timing belt tensioner bolt into the block?
Doing my water pump and timing belt and i stripped the bolt for the tensioner off like a dummy. -_- I would just leave it however the timing is off so i cant unfortunately
Unless anybody has any tips to rotate the left cam (driver side) a few notches without removing the tensioner im going to have to extract the bolt either with a bolt extractor bit or by drilling it out. If it comes down to drilling it out im very nervous because i think the tensioner bolts into the aluminum block and i don't want to **** it up. Any advice?
Old Yesterday, 07:22 PM
SexCoupe
SexCoupe's Avatar
What bolt did you strip exactly ? the allen key style?
Old Yesterday, 07:54 PM
Kxdza
Kxdza's Avatar
The bottom bolt. There's 2 bolts that go into the bottom. It's not the roller part but the tensioner part that pushes up into the roller. It's a 12 mil. This thing
Old Yesterday, 09:21 PM
SexCoupe
SexCoupe's Avatar
how do you know you need to extract it?? it is very difficult to cross thread those 2 bolts
Old Today, 02:54 AM
Kxdza
Kxdza's Avatar
Sorry I was pretty tired and frustrated when I wrote that up last night. It’s not stripped it’s snapped off in there
Old Today, 10:32 AM
SexCoupe
SexCoupe's Avatar
its not a big deal. figure out what thread pitch it is then buy a helicoil kit that matches. drill and tap and insert helicoil.
You could also remove the rocker tensioner and try to extract the bolt from the opposite side.
or although not recommended if you have a 91-94 sc400 you could just use one bolt. if the bolt breaks youll just have to tow it home and redo the entire job with the helicoil.
Old Today, 12:10 PM
Ali SC3
Ali SC3's Avatar
If it is snapped off then removing the other bolt should allow you to remove the tensioner.
Then see if you can get vice grips on the snapped bolt end and back it out, if not then its a drill it out carefully and tap the threads situation.
If you have a bolt extractor set with left hand drill bits you can try that.
The tensioner usually doesn't bolt into the block, it'll usually go into the oil pump which is not easy to remove without pulling the engine so I would go slowly and try not to damage the threads.
Whitefarms (Today)
Old Today, 12:36 PM
Kxdza
Kxdza's Avatar
The one that snapped off is the one that bolts into the enclosed area (the oil pump). I have a screw extractor drill bit set but maybe left hand drill bits would be a better option?
Thank you for the reply
Old Today, 12:40 PM
Kxdza
Kxdza's Avatar
Whats the advantage to the heli coil over a regular drill and tap? Is it just that it will match the original threads or is there something I’m missing?
Thank you for the help
Willauflex
08-27-19 08:02 AM
Akshaan
02-08-17 08:08 AM
YODAONE
02-06-17 02:02 AM
YODAONE
19
02-02-17 09:11 PM
gtstcactus
04-12-15 06:50 PM
Quick Reply: Does the sc400 timing belt tensioner bolt into the block?
