Ride height
Old 10-07-24 | 08:37 AM
step430's Avatar
step430
8th Gear
Question Ride height
My ride height on my 2001 ls430 UL is uneven; the front left of the car is higher than every other part. The ride though is still very comfortable. Any information helps!
Old 10-07-24 | 10:26 AM
paulo57509's Avatar
paulo57509
The attachment will show you how to measure the ride height. Once you determine if you're out of spec, you can proceed with corrections.
File Type: pdf
Old Yesterday | 08:43 AM
step430's Avatar
step430
8th Gear
I just measured the ride height by a stick and noticed that the front left suspension is higher than all the other suspension. But I'm not sure if its because of faulty air suspension or what.
Old Today | 01:06 AM
BigBoomer's Avatar
BigBoomer
How much higher?
Did you make 100% certain that the ground you measured it on is completely level?
Additionally, are all 4 tyres the same size and make/model?
Did you cycle the ride height twice like it says in section 3. w/ Electronic modulated air suspension: ?
04-02-23 06:30 PM
str8hust1a
05-22-12 09:11 AM
VIS250P
04-02-11 07:45 PM
Zender
Suspension and Brakes
31
06-30-08 12:02 PM
MCV20
18
06-06-04 08:13 PM
Quick Reply: Ride height
