What did you do to/for your sc430 today?
Old 11-18-15, 01:31 PM
Coleroad
Coleroad's Avatar
Default What did you do to/for your sc430 today?
Starting this thread with the hope everyone enjoys it. It gives a place to show even little things that one wouldn't start a thread for. This is a very popular thread on the BMW forum I'm on. Popular enough it was made a sticky on that forum.
So i'll start. I gave mine a full detail today inside and out.
I tried the turtle wax jet black, black endurance-shine tire coat kit. Hope it lasts longer and looks better than the silicone based tire dressings.
Attached Thumbnails What did you do to/for your sc430 today?-image.jpeg
The following 6 users liked this post by Coleroad:
Carin143 (04-12-22), judie (03-22-22), Morobi (04-03-23), Sungirl (11-12-19), ThomasD94 (06-12-20), tromly (10-21-19) and 1 others liked this post. (Show less...)
Old 11-18-15, 01:32 PM
Coleroad
Coleroad's Avatar
A picture of the engine bay.
The following 2 users liked this post by Coleroad:
Old 11-18-15, 08:52 PM
GmanSC
GmanSC's Avatar
Nothing. Mine still practically like new. still playing wth the Nav, and still trying to clean the finger print marks off with no success. Guest I have to install the screen protector.
Carin143 (04-12-22)
Old 11-19-15, 09:33 PM
SC430fun
SC430fun's Avatar
I was very recently thinking about creating this thread as well! Its on the Lincoln and Thunderbird forums and the thread is very popular and huge over there.
Old 11-20-15, 06:08 AM
Coleroad
Coleroad's Avatar
It doesn't seem to be hitting anybody's fancy over here though.
Rickoddone (10-05-20), TNSC430 (08-22-21)
Old 11-20-15, 10:00 AM
Retroplay
Retroplay's Avatar
I installed the replacement temperature control unit today.
This morning I picked up a desiccant bag for the car which will supposedly help prevent fogging and frost from forming on the windows. We shall see soon.
Later, if I can find the time, I would like to finish up my center console mod.
I like the idea of this thread. I think activity has just been down here recently. It always comes and goes in these forums, especially with a specific model forum like this one.
tromly (01-07-20)
Old 11-20-15, 10:07 AM
Coleroad
Coleroad's Avatar
Yes, I guess it is winter now, and a convertible car. I kinda forgot with it still being warm here. Lol you would think I lived here longer than just one year. I think this kinda thread helps instill pride in even the small things one does to take care of their car. I know even when I just get new tires I'm excited.
tromly (01-07-20)
Old 11-20-15, 05:57 PM
Cube
Cube's Avatar
Recently I managed to take off centre control panel to check the motorized door radio panel. moves fine but doesnt work. im trying to look for the fuse (if it were separate), but I only found one radio fuse (RADIO NO.1). read in some other threads that the gears could be off its hinges, but the movement (manual pulling and pushing) seems fine. Could it be a bad switch as some members said it could be?
Old 11-20-15, 06:04 PM
Retroplay
Retroplay's Avatar
Well, let's look at the possibilities. Could be a fuse, the switch, switches in the mechanism itself, wiring issue, bad motor, broken gears, or misaligned mechanism.
We can eliminate at least some of those with two questions:
1. Does the door button light up?
2. When you press it, do you hear the motor running?
Old 11-20-15, 06:29 PM
Cube
Cube's Avatar
I will double check on it later. But initial diagnosis were answers to both will be no. It doesn't light up and motor doesn't seem to be running.
Old 11-20-15, 06:35 PM
Retroplay
Retroplay's Avatar
If it doesn't light up, I would suspect the wiring or the plug going in to the switch.
The light is just connected to the illumination circuit used throughout the car. The switch goes to a circuit board on the door that controls the motor. The only thing the two have in common is that plug/harness.
On mine, it was wire tied rather tightly. If the plug is not loose, it could be broken wiring at the zip tie.
There are two clips on either side of the switch which will let you pull the switch out for easier inspection.
Old 11-20-15, 06:40 PM
Cube
Cube's Avatar
Thanks for the advice, Retro. I will try and check it out tomorrow. Saturday is a working day for us. .
Old 11-21-15, 08:09 AM
Retroplay
Retroplay's Avatar
I just noticed you are in Brunei. My fiance was working overseas there when we met. She was in Seria/Kuala Belait.
Old 11-21-15, 10:50 AM
Retroplay
Retroplay's Avatar
Not doing much to the SC430 today. But she could really use a warm blanket
Winter is here!
The following 2 users liked this post by Retroplay:
714Vanderb (08-07-20), Lavoisier (08-23-22)
Old 11-21-15, 10:55 AM
Coleroad
Coleroad's Avatar
Winter is here!
I'm not missing the snow. I think it's bad enough at 65 and rainy today.
Quick Reply: What did you do to/for your sc430 today?
