2004 GX470 belt moulding
![Question](https://www.clublexus.com/forums/images/icons/icon5.gif)
Have any of you replaced the front right window belt moulding? If so, how do I remove the old moulding?
The upper strip on mine stated flapping and so I tore it off.
You're talking about the strip along to top edge of the door/bottom of the window? It's held on with plastic clips, pull/pry up and off. If you break clips, you can buy new from dealer. New belt molding may even come with new clips.
Probably best not to forget to remove the screw on the end of the moulding before you go yanking on it. Lots of youtube videos on this subject.
ancdmd
04-16-16 07:03 AM
