HELP! 1998 Lexus GS300 Car Radio Wiring
Old 09-29-16, 10:03 AM
Laza1
Registered User
Laza1's Avatar
Default HELP! 1998 Lexus GS300 Aftermarket Radio Not Working
Hwllo i trying install aftermarket radion on my GS 300.
Here is the wiring:
1998 Lexus GS300 Car Radio Wiring Chart
Car Radio Battery Constant 12v+ Wire: Blue/Yellow
Car Radio Accessory Switched 12v+ Wire: Gray
Car Radio Ground Wire: Brown
Car Radio Illumination Wire: N/A
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 5 1/4″ Speakers
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Pink
Left Front Speaker Negative Wire (-): Purple
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Blue
Car Audio Rear Speakers Size: 5 1/4″ Speakers
Car Audio Rear Speakers Location: Rear Doors
Left Rear Speaker Positive Wire (+): Black
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Red
Right Rear Speaker Negative Wire (-): White
I have a BIG PROBLEM! I don't have a BROWN colored cable...
I wired Car Radio Battery Constant 12v+ Wire: Blue/Yellow
and Car Radio Accessory Switched 12v+ Wire: Gray but I can not turn on the radio!!! Please help!
Old 09-29-16, 10:28 AM
Mr Jokster
Mr Jokster's Avatar
Well, the brown wire is a ground, so just attach the ground from the radio to something metal. I cant remember whats behind the dash, but just find a metal facing with a screw/bolt and use that as a ground. Be sure that the metal plate is attached to the body somewhere. If not, then just extend the ground wire from the radio and find a ground anywhere, even if you have to go all the way to the battery.
But what I wanna know is, why would you cut the factory wiring and ruin the harness? They make plug in kits ya know.
Old 09-29-16, 11:08 AM
Laza1
Registered User
Laza1's Avatar
I hate factory radio and i dont need this!
i have pionner lcd bug.
So i wired 12v cables but radio wont on or off. Next???
Old 09-29-16, 02:06 PM
Mr Jokster
Mr Jokster's Avatar
As I said, they make a plug and play harness for after market decks as to not cut anything, I said nothing about keeping it stock
And I did give a solution to your problem with the ground problem, please reread
Old 09-30-16, 06:33 AM
Laza1
Registered User
Laza1's Avatar
Thank you! you have a private message but i solved this problem!
Ground problem not solved trying solving now.
Old 09-30-16, 11:22 AM
Laza1
Registered User
Laza1's Avatar
SOLVED!! Next step: power on the factory amp with my new stereo!!!
Anybody help me? I need factory amp! No bypass.
Old Yesterday, 11:25 AM
T3riple
1st Gear
T3riple's Avatar
I agree on not cutting harness when ever possible. As for a ground find a screw and use it. Make sure the wire is between the head of a screw and the metal. Use a wire connector if you have one. Don't run it to the battery. Keep the wire short but long enough to pull the radio out later. 6 to 9 inches. Or you can get engine idle/rev feed back when the car is running. If you plan to put an amp in at some point keep the wire 18 inches or less or you will get feed back. This goes for any car. Just adding my two cents on running a ground to the battery.
Old Today, 01:43 AM
JohnnyGS4
JohnnyGS4's Avatar
8 years old bruh LOL
Barizpe
10-07-15 08:24 AM
JSC4
04-19-13 07:31 PM
jmac2k11
GS - 1st Gen (1993-1997)
10-14-12 09:12 PM
amart79196
09-13-08 04:44 PM
Quick Reply: HELP! 1998 Lexus GS300 Car Radio Wiring
