How wide a tire can the stock 20" OEM rims allow without rub?
Old 09-19-17, 09:58 AM
nipik
nipik's Avatar
Default How wide a tire can the stock 20" OEM rims allow without rub?
I have a 2016 LExus RX350 F Sport. I want to change my tires to wider tires keeping the same OEM rims. I want to put the 265/50 R20 on the stock OEM rims. Will this cause a rub?
Old 09-19-17, 10:26 AM
FastFord
FastFord's Avatar
Probably not...check this tool, it gives all sorts of info
https://www.wheel-size.com/calc/?whe...cl=30mm&sr=0mm
Old 09-19-17, 11:40 AM
nipik
nipik's Avatar
@ FastFord: Thanks a bunch! Awesome tool.
Old 09-19-17, 01:07 PM
FastFord
FastFord's Avatar
You are welcome...Let us know how it rides if you go that route!
Old 09-20-17, 09:59 AM
aswang
aswang's Avatar
Curious to know as well, would love to see pictures too. =)
Keep us all posted!
Old 09-21-17, 03:42 PM
nipik
nipik's Avatar
Smile 265/50R20 with OEM Rims
Had 265/50R20 XL (111V) Pirelli Scorpion Verde installed today. No rub, smooth ride. Used F Sport OEM 20" rims. the tire fits perfectly and leaves 15mm of space between the inner tire edge and the suspension spring.
No issues turning, braking or maneuvering. Thanks for your help! Posted some quick picks while the folks from ASAPtire were installing the tires in my garage - awesome home service.
Attached Thumbnails How wide a tire can the stock 20" OEM rims allow without rub?-img_20170921_095711.jpg   How wide a tire can the stock 20" OEM rims allow without rub?-img_20170921_095700.jpg   How wide a tire can the stock 20" OEM rims allow without rub?-img_20170921_113846.jpg
The following 4 users liked this post by nipik:
aswang (09-22-17), CharmCtyIS (10-02-18), FastFord (09-21-17), Hubs (12-23-18)
Old 09-21-17, 05:50 PM
FastFord
FastFord's Avatar
That's a good looking set-up...you move fast....How big a tire, thanks, here they are!
Old 10-01-18, 12:29 PM
aznkorboi
aznkorboi's Avatar
Sweet. SO you got 265 55/20's correct? Does this mean I can get any tire that size and install them?
Also, what are the benefits of that size?
Old 10-01-18, 02:06 PM
nipik
nipik's Avatar
Default Tire width is limited
You cannot use any width, or you will have rubbing take place. 265mm is the widest I would put because 275mm will cause you to have no clearance when you turn. This will result is scuffing and potentially a dangerous condition. The wider tires look nicer, especially on the FSport trim, or even if you have the regular trim. It results in a softer ride as the weight is distributed on a larger surface, though I couldn't really tell the difference. The Pirelli Scorpion Versé are far superior that the OEM Bridgestones they come with.
The speedometer is however affected as the tire revolutions will change. Recall C=2*3.1415*R. So the bigger the total C resulting from the tire ratio of width, the faster you are traveling. Your car speedometer is calibrated for the OEM size so just know the impact. My size hardly makes a difference on the freeway 3-4 mi underestimating at 70 mph.
Old 10-01-18, 02:23 PM
aznkorboi
aznkorboi's Avatar
Wow. so scientific lol. Thanks for the info. They have the michelins premier ltx in 265's so I was curious. haha. Thanks man!
Old 10-01-18, 06:01 PM
wktjr
wktjr's Avatar
Two sites I use.
https://www.miata.net/garage/tirecalc.html
https://www.1010tires.com/Tools/Tire-Size-Calculator
Old 12-08-18, 06:02 PM
RogueRX
RogueRX's Avatar
What tire pressure did you set your new tires at? I’m scheduled for tire installation next week. I went with the Michelin Premier LTX 255/50/20XL 109V. They are a bit narrower than your tires but I would like to get an idea how much pressure to set them at. Thanks!
Old 12-09-18, 01:16 AM
BensonTT
BensonTT's Avatar
Wider tires = bad gas mileage right?
Old 12-10-18, 05:26 AM
raysmd
raysmd's Avatar
Thanks for doing the legwork. I’m glad 265/50/20 tires work. I’ll be putting on the Michelin Defender LTX in the same size for my f-sport once the premier’s are done.
Old 12-11-18, 03:49 PM
RogueRX
RogueRX's Avatar
I was finally able to do this. Got them from Costco on sale for $842 all in. Didn't want to waste the OEM tires so I used them for over 21,000 miles (around 3 years). Now that I have the wider tires, I regret not getting them sooner. I feel that these should be the tires that Lexus ships the 4th generation RX F Sport with. I know it's all about fuel economy and I'll probably take a slight hit on that but the difference in handling is really significant. The RX feels much more planted on the road with these tires on. I was smiling on my way home.
Michelin Premier LTX 255/50R20XL 109V
Hubs (12-23-18)
Quick Reply: How wide a tire can the stock 20" OEM rims allow without rub?
