Brake Caliper Torque Specs (Front & Rear)
09-28-17, 04:47 PM
Hey guys! I'm getting ready to do a brake job (Front and Rear) but first want to verify that I have the correct torque specs before I get started.
Front Caliper Bolts: 58 lb-ft
Bridge Bolt: 22 lb-ft
Rear Caliper bolts: 40 lb-ft
Can anyone verify that these numbers are correct via the service manual? Thanks for the help!
09-28-17, 09:47 PM
the quick answer is yes those numbers are correct. I'm having a hard time finding the diagram
09-29-17, 10:40 AM
Quote:
Originally Posted by
ZDCATC
Thank you very much, ZDCATC! I appreciate it. I really don't need to see a diagram, I just wanted someone to verify that those specs were correct.
Thanks again!
09-29-17, 01:07 PM
I used the same spec doing my fronts recently.
09-29-17, 04:04 PM
stvincent
Thank you!
10-28-19, 06:21 AM
10-25-22, 01:57 PM
1st Gear
10-25-22, 05:32 PM
This one. It's only on the front calipers.
13mm 22ftlb/264inlb
09-28-24, 07:47 PM
Does anyone have a service diagram for this?
Yesterday, 11:12 PM
cpforyou
Front brake "hardware kit".
Today, 12:57 AM
ChpEng
If you look at the brake caliper picture 2 posts above yours, it shows exactly where all those parts go.
B777Pilot
01-16-21 07:45 PM
MickeyS
ES - 5th Gen (2007-2012)
05-27-16 06:17 AM
RHui_BC
Suspension and Brakes
09-06-09 08:50 AM
jimbo22s
Wheels, Tires & Brakes Forum
08-22-08 04:58 PM
fstepanov
09-22-05 06:25 AM
