Best struts for smooth ride??
Earlier this week my trusted Japanese car mechanic replaced the original struts on my 2002 180K mile RX300 with new KYB struts. The ride is now AWFUL! - Stiff, hard, & no cushioning, and I can feel every pebble on the road. I want my smooth, cushiony Lexus ride back. I don't mind paying for the labor again to change them out. What brand should I ask him to use? I never had noises, rattles or loose steering issues with the old struts, but it was feeling bumpy and like it needed "shocks" when driving on typical moderately rough city streets. It was still riding smooth as silk on highways and smooth roads. Would appreciate any experienced input!
None.
I have done countless struts on various makes out family owned.
It is strange thing. Once shocks have to be replaced, literally nothing will restore the original quality of ride. And have my word, I did cheap shocks, expensive shocks, adjustable shocks, OEM shocks - does not matter. Ride is never the way it was.
My take on this is - there are way too many components involved into pleasant suspension ride, to replace just one. Though I replaced shocks and control arms one time - not much difference too. Short of entire suspension overhaul, I do not see a way to completely restore original feel.
Some will say - oh, what you talking about. I did this or that and it feels great. Well, sure. For few weeks, then what? And those posters usually do not repost after several months of use, with same delight. Some of it is psychological aspect. I invested yey much money into this, of course it feels better or, I shall say so.
Here's one and only thing, so far, and I worked on my cars since 1990, that worked. On my then Camry hybrid, I did front end Monroe shocks replacement of strut assembly. You know, strut is actually not just shock. Springs, two rubber insulators, bearing plate. Assembly. It sucked the usual way. Good for few weeks, then ewwww.
So I replaced them with Monroe Quick Strut. a) it was breeze to do. 20 minutes per side. b) they sort of sucked originally but slowly yet surely, they "opened up" and became very comfy, actually. Soft, cushy. Took about 4-5 months, but then ride turned out to be very fine.
That's my experience. I did front end KYB (KYB or Tokico are OEM shocks for Toyota) shocks component on my 2012 Highlander and - yep, they suck. I wish I could find Quick Strut for it, but no one makes them for the year. There is unknown to me company that does but I do not buy unknown.
You could simply reduce the air pressure in each tire by 5lbs. That will give you a bit of cushioning.
Don't you find the handling more precise (less vague) with stiffer shocks ? I always thought the Lexus RX drove like a Japanese Buick. A bit mushy. This is worsened when the seats offer little or no bolstering to hold you in place if you have a slim build.
KYB is known, for their aftermarket dampers, and I've found them to always be a bit aggressive. This has worked for every vehicle I've put them on, including the '95 Mercedes W124 sedan which still has its OEM Bilsteins on it. However, that car needed to be more aggressive in the suspension department.
You think the change to KYBs is bad, eh?
Try going from an '08 LWB LS 460 L with air suspension, to an '02 RX300 AWD. The difference is disturbing.
The LS feels like a 1973 Coupe DeVille, but under slightly better damping control and a couple of feet shorter (I'm not kidding), but the RX feels 'busy' all the time. Suspension is OEM, and to be fair, the RX is a mid-size, FWD platform which is now 16 years old, even if it has only 144K miles on it.
I'm sorely tempted to replace the struts, but I don't yet know with which ones. I'd love to try Koni out on it, but dampers are not made for the RX by them.
If anything, when dampers (shocks, or the shock part of the strut) wear out or develop leaks, typically ride gets more floaty and, for lack of a better term, indecisive. It shouldn't tighten up and be more sensitive to input (bumps/holes)
FWIW, the KYBs aren't going to 'soften up' any noticeable amount, either...at least the six sets I've put on six different vehicles, didn't. We'll come up with something.
mckellyb (01-21-18)
As usual, to each of his own. Mine did. Loosen. Now I need to replace rear ones as now I can tell difference between already replaced front and rear ends.
I shall go with complete strut. Reason I didn't do it last time was I could not find them for my vehicle. There is only one brand on ebay that sells them. That brand I have never heard of but, I already came across a favorable end user review of them. I'll take chance. That said, on my then Camry I did Monroe Quick Strut and after about 3-4 months, that car drove very comfortably. Very. With, actually, KYB strut shock component in the rear. I first did Monroe strut shock in the front then, as usual, it didn't do much, then found Quick Strut and replaced them with Quick Struts after about 7 months of use. Was very pleased.
mckellyb (01-21-18)
I'm quite glad to hear yours mellowed out a bit, ukrokoz, because I really want to put KYBs on my wife's RX seeing as Koni doesn't make anything for it, but the last thing I want is for it to ride any 'tighter'.
The LS has spoiled me...badly.
Lyn struts produces a horrible ride on my 02 Lexus
I replaced my 02 Lexus ES300 quick struts with the original Lexus springs and purchased 2 KYB front end struts. My car now rides so rough until it feels like there's nothing there. I spent a nice penny replacing the original springs and the KYB's wasn't cheap either, any suggestion on how to get my smooth ride back? ]
Sachs / TRW are pretty soft, I have those on my RX350 and they are pretty close to factory. The KYBs are definitely a good 20% stiffer or so than factory. I've got the KYBs on my 2002 Highlander which came with factory KYBs and I love the extra stiffness they have, but I prefer firmer suspension.
A lot of us have owned that gen ES a long time; we have one w/340k on it now. It drive, rides, and looks great. Factory spring rebuild with KYB shocks make most people quite happy. Moog makes a decent replacement rear spring if the backs are shot (I and others are using them). The rear springs fail after higher mileage, the fronts never seem to fail. If you have all Lexus springs, and KYB shocks, and it feels bad - then something has been overlooked - upper mounts, busted control arms, etc.
qha_vn
06-14-14 02:43 AM
