P0174 engine fault is this related to lambda Oxygene sensor bank 2 sensor 1??
Hi guys. I have a problem with my rx350 2006. Engine fault with VSC on my dash. Fault code is P0174 system too lean bank 2. I have replaced MAF sensor as it was suggested. But still nothing.. Someone said that it would be lambda oxygen sensor bank 2 sensor 1... Anyone had a similar problem? Is this will resolve the issue..?
if you have access to a scanner. watch b1s1 and if you see the voltage move from .8v to almost 5v. this is normal. then its not the MAF. If it were, you would see it stuck at either near .8v or 5v. i dont remember if lower voolate means lean or rich. Either way. Go ahead and replace the b2s1 o2 sensor.
Hellojenna
RX - 1st Gen (1999-2003)
08-03-17 08:58 PM
Es300guy2k
12-25-16 11:33 AM
