Odd air conditioning Issue
I recently bought a 2018 lx570 and im having a weird air conditioning issue what i wanted to see if anyone else may have experienced. The front two drivers side vents will not blow air, but the rest of them work fine. The fix the first time when i took it back to the dealer was to 'reset the system' whatever that means. They did the same thing the second time and it worked for about 600 miles. This time, its been in the shop for about a week and the dealer cant figure it out. Anyone have any ideas. Upside is, it has 5k miles on it so if they dont fix it this time, there going to get it back under the lemon law, but i love the car and hate to have to go through that.
Thoughts?
Thoughts?
I really don't see how this is possible short of a physical blockage because the venting is relatively clear through to the unit. I can't imagine how it can take a week to figure it out. Not sure why they can't phish a line into the system and see if there is a manufacturing defect (ie blockage) in the line.
DID THEY VALIDATE the problem, seems like something they can do right in front of you.
Of course it does. CAF has to be changed with the recirculation door OPEN. Moving the door manually from closed (outside air) to open to change the filter will intercourse the system, big time.
If that doesn't work, this post on mud should give you info on escalating the fix...200 Series Cabin Air Filter R&R
hth
Any help The front two drivers side vents will not blow air, but the rest of them wor
Thoughts?
Thoughts?
The recirc door issue, should not cause the vents to not work, you just stay in recirc mode constantly. It manifests as fogging on the windows in cold weather due to no fresh air. This vent issue still seems like that same TSB issue about resetting the AC system that you already had done. The complaint is exactly the description of the problem. Otherwise it must be a non functioning motor or blockage.
