Exhaust valves
Old 12-28-19, 08:24 AM
tiger1918
tiger1918's Avatar
Default Exhaust valves
Has anyone tried to disconnect the exhaust valves so they stay open all the time. Did this on my Ferrari and Lamborghini and sounds great. Thanks
Old 12-28-19, 08:32 AM
hoonose
hoonose's Avatar
I first thought you meant the exhaust valves in the motor! lol
tommydogs (11-05-21)
Old 12-28-19, 08:51 AM
flowrider
flowrider's Avatar
Received 1,920 Likes on 1,355 Posts
I have the PPE Dual Mode exhaust, and the valves on it are controlled by a remote. So, yes Didn't have my stock exhaust that long, so never fooled around with it.
Lou
Old 12-28-19, 09:03 AM
Puertex
Puertex's Avatar
Lou
What does it take to install the PPE DME?
Thanks,
Puertex
Old 12-28-19, 11:35 AM
flowrider
flowrider's Avatar
^^^^There is equipment (mainly under body panels) to remove, but it's basically R&R. I also have PPE EL headers. Header installation is more complicated.
Lou
Old 12-28-19, 11:36 AM
pottypants
pottypants's Avatar
Thanks,
Puertex
its a whole exhaust system with pipes.
can always consider cut outs...
Old 12-29-19, 06:14 AM
SuperGT
SuperGT's Avatar
Yes I did and it's the only way to go on the LC original system IMO. Also tried it on my Aventador but went back to the drive-mode controlled set-up as the adrenaline pumping Corsa mode sound does get tiresome for ''casual'' drives.
Old 12-29-19, 07:34 AM
pottypants
pottypants's Avatar
so spill the beans
how does one make the oem flaps remain open ?
default is open so disconnect ?
Old 12-29-19, 11:54 AM
SuperGT
SuperGT's Avatar
Originally Posted by pottypants
so spill the beans
Correct, default is open. Just be sure to properly secure the four harnesses up and away from the exhaust pipes and seal the connectors to protect against water and dirt. Won’t trigger any cluster lights or code.
pottypants (12-29-19)
Old 12-29-19, 01:19 PM
pottypants
pottypants's Avatar
awesome ! Thanks so much !
service dept gave bad info twice now, but compared to Chevy I’ll take them every day !
edit: just did the mod. I would assume only one connector on each side needs to be disconnected. It’s rainy and cold, I’m not going to play just removed all 4 and taped up the ends.
Thanks again
ppp
Old 12-29-19, 02:11 PM
SuperGT
SuperGT's Avatar
Thanks again
ppp
Good thing you did both harnesses for each valve as they are managed by separate modules. One is according to drive-mode setting and the other activates the valve according to rpm/throttle position/speed. Enjoy!
Old 12-29-19, 04:59 PM
asinow
asinow's Avatar
Any chance you have a sound clip? Maybe you can post an after clip if you dont have both?
Thanks...
Old 12-30-19, 05:17 AM
SuperGT
SuperGT's Avatar
Thanks...
No I don't. Once you make it under the car it's only a 15 minute job so it can easily be reversed anyway...but that point is mute since you'll never go back.
asinow (01-09-20)
Old 12-30-19, 06:38 AM
Puertex
Puertex's Avatar
So you have left it open permanently?
Puertex
tommydogs (03-26-22)
Old 12-30-19, 06:43 AM
SuperGT
SuperGT's Avatar
Puertex
Yes. Compression pops and occasional backfires are included 👍🏻
Quick Reply: Exhaust valves
