Back seat panel not staying up
Old 07-20-20, 12:22 PM
Robles84
Robles84's Avatar
Default Back seat panel not staying up
Hey everyone...
just picked up a 2010 rx350 for the family.
and the back compartments for the driver and passenger seat are not staying up. Any suggestions on how to fix to stay closed
Old 07-21-20, 10:41 PM
Robles84
Robles84's Avatar
No help smh
Old 07-22-20, 05:22 AM
RX in NC
RX in NC's Avatar
Must be a very rare issue. Give it more time for someone who has also experienced this problem to reply to you.
Old 07-22-20, 09:08 AM
NickSP
NickSP's Avatar
It's hard to tell from the pictures what's wrong. Or what's not staying up.
Old 07-22-20, 12:56 PM
Clutchless
Clutchless's Avatar
Received 1,182 Likes on 1,010 Posts
They probably jammed too much stuff back there and broke the spring or whatever it is at the bottom that holds it flat against the seat back.
You can replace the back panel which contains that part and folks are selling them on eBay. The prices are all over the place from $38 for an ivory one to a bunch for $124. Search RX350 seat back panel OEM. It may be a good idea to pay a car upholstery shop to install it for you.
Old 07-22-20, 03:55 PM
Robles84
Robles84's Avatar
Here is a actual picture of what I'm talking about
Old 07-22-20, 05:13 PM
Clutchless
Clutchless's Avatar
Or get some velcro strips where you peel off the back which is sticky and insert them inside the seat panel and hope that will hold it in place.
chas410 (07-30-24)
Old 07-22-20, 06:14 PM
NickSP
NickSP's Avatar
That entire seat back seems snapped on to the back. The plastic part. Pulling it out may lead you to changing the bands responsible for flexibility.
NavyVet (07-24-23)
Old 07-23-20, 04:42 AM
RX in NC
RX in NC's Avatar
I like the velcro suggestion. That would be my initial attempt to fix this issue. We never store anything in the seatback pockets of any of our vehicles, so keeping those pockets permanently closed at low cost would be my goal.
chas410 (07-30-24)
Old 07-25-20, 09:23 AM
Robles84
Robles84's Avatar
Just found a link in the DIY section.
it was under DVD headrest install. Member removed the back seat panel. So I'm going to start when I have time. Hopefully it's a quick fix
Old 09-21-20, 06:18 PM
Robles84
Robles84's Avatar
so I fixed the issue. Pretty simple and fast did both side in about 8min. The elastic was stretched out so I just zipped tied both end together in the back. Now they are looking good and my kids aren't using them as foot rest anymore lol
nsnqst (09-22-20)
Old 04-16-21, 11:18 AM
macgreen
macgreen's Avatar
Default Lexus RX350 2010 Back Seat Panel Help
Hi, I have a 2010 Lexus rx 350 and today I went behind the seat and found the panel that holds things in the back has been snapped and broken. I’m heart broken and don’t know how to fix it so it doesn’t look as bad. Any suggestions are greatly appreciated!
Old 04-28-23, 08:47 AM
Frank2023
5th Gear
Frank2023's Avatar
Default Back panel won’t stay shut
My fix…two screws hold back panel on. Remove them and pull out, then pull whole panel down. There is a cover over screws. Just unhook fabric. My elastic had stretched so just connected two ends with zip tie. Good luck.
The following 3 users liked this post by Frank2023:
Clutchless (04-28-23), jpajya (08-02-24), Lexamongus (06-22-23)
Old 04-28-23, 11:34 AM
RX in NC
RX in NC's Avatar
Well done.
Old 06-22-23, 10:54 AM
Lexamongus
10th Gear
Lexamongus's Avatar
Great information. Thank you.
Quick Reply: Back seat panel not staying up
