UX Models (2019-present)
Illuminated door sills
Old 09-15-20, 06:11 AM
Funride
Funride's Avatar
Default Illuminated door sills
Has anyone added these to their car?
Old 09-16-20, 09:55 AM
CARuiser
CARuiser's Avatar
Yes, I installed the Lexus branded door sills with my son. It took about 20 minutes.
Can't speak about non OEM, but the branded ones came with the connector brackets included, so no need to splice wires, which was a concern of mine. My biggest issue with the lights is they are constantly on, along with the floor mat lights.
If you have a specific questions, please ask.
Old 09-16-20, 01:14 PM
Funride
Funride's Avatar
The floor mats are something separate - correct? So no need to drill to install the door sills? Are directions included? I will have my son do this for me.
Old 09-19-20, 02:54 PM
CARuiser
CARuiser's Avatar
No drilling is required. Assuming you get the Lexus branded door sills it is all plug and play. Install directions can be sourced from the parts department when buying the part. We figured it just by doing it. Directions will make it much easier.
Old 09-19-20, 07:50 PM
Funride
Funride's Avatar
Thanks - I want to install these now that it's getting darker earlier. Didn't need them this summer, but think they will be nice in the evening.
Old 09-19-20, 09:23 PM
CALtd
CALtd's Avatar
$325 for set of 4. rear do not have lights.
Illuminated Door Sills
Old 09-20-20, 06:49 AM
Funride
Funride's Avatar
Thanks for the info.
Old 09-24-20, 07:22 PM
CRS1
CRS1's Avatar
[QUOTE=CARuiser;10893960]Yes, I installed the Lexus branded door sills with my son. It took about 20 minutes.
where are the connections for the driver & passenger side located?
Old 09-24-20, 07:33 PM
CARuiser
CARuiser's Avatar
[QUOTE=CRS1;10900188]
The connections are at the footwell light. You remove the connector at for the footwell light and install it into the connection for the door sill, then connect the other door sill light bracket where the footwell light was.
So below the glove compartment and below the dash.
Old 09-25-20, 09:10 AM
Funride
Funride's Avatar
I ordered these last night - the OEM's were on sale - $225 for the complete set.
Thanks for the responses.
Old 09-25-20, 02:02 PM
CALtd
CALtd's Avatar
Online order or local dealer?
Old 09-26-20, 07:45 AM
Funride
Funride's Avatar
Ordered online.
Old 10-08-20, 08:24 AM
Funride
Funride's Avatar
Well the door sills arrived but my son tried to install them and the ones for the back don't seem to match up. They should just snap in like the original ones - correct?
Did anyone who installed them have access to the PDF file for installation? He thought he could do this but is confused.
Old 10-08-20, 03:42 PM
CARuiser
CARuiser's Avatar
Sorry no instructions. Try emailing the place you sourced them from. It should just be pushed in.
just in case you didn't do it, is it possible you swapped the passenger and driver side back door sills?
Old 10-09-20, 09:29 AM
Funride
Funride's Avatar
I'm pretty sure he had them on the right side. Will contact the source and see if they have anything.
Thanks
Quick Reply: Illuminated door sills
