How to clean "black" lower read door paint protectors
Old 01-09-23 | 07:59 AM
ovation's Avatar
ovation
10th Gear
Default How to clean "black" lower rear door paint protectors
The clear paint protector patches that Lexus applies in front of the rear wheel wells on the 6th gen ES darken with age. They turn black. The look awful, especially on white and light colored ESs. I have a 2013 ES with this problem. My car is gray, so the "black" doesn't stand out as much as on a lighter colored car. But - I found a great way to fix it.
1) Use "Scratch Out" from Formula 1. Rub for about 3 minutes. Reapply until black is gone and your cloth is clear. You can buy this at Walmart.
2) Wax with Mothers Reflections Top Coat.
I just did this yesterday and was amazed at the result. See before and after pics below.
The following 2 users liked this post by ovation:
Nelexus88 (01-11-23), PMIRO2 (10-29-24)
Old 01-10-23 | 06:52 AM
bc6152's Avatar
bc6152
Looks pretty good... You could also probably use the solution for cleaning the clear headlight covers...
Old 01-10-23 | 08:03 AM
Tootsall's Avatar
Tootsall
Good trick. Imagine what the door would look like if there wasn’t a protector on there!
Old 11-12-23 | 05:29 PM
ovation's Avatar
ovation
10th Gear
Update 11/2023 - 10 months later and the protectors have turned black again. Also, due to our first summer in south Florida tge sun fried them and they have cracked. The steel expands with the strong sun, and the 10 year old protectors are now more brittle and crack.
I uaws plasric razor blades and 3M adhesive remover to take these off. It comes off without much work, and the paint is perfectly new under these.
palmoyas (10-28-24)
Old 10-28-24 | 08:29 AM
rickster9's Avatar
rickster9
Did you heat it up first?
Old Today | 04:46 AM
ovation's Avatar
ovation
10th Gear
No need to heat it up. Just start with the plastic razor blade. Remove what you can with that. Then adhesive remover to get off all the glue. Then scratch off to polish it.
1999sel
Build Threads
16
03-11-17 06:40 AM
tstead
ES - 5th Gen (2007-2012)
04-07-07 07:49 AM
np20412
Automotive Care & Detailing
13
02-18-06 10:01 AM
Bluesman
05-20-03 01:34 AM
Lvangundy
14
05-07-03 05:00 PM
