Secret to remove OEM wiper bade for replacement
Old 01-30-23 | 11:42 AM
davidcvigi's Avatar
davidcvigi
Question Secret to remove OEM wiper bade for replacement
Help! I ordered new Lexus OEM wiper blades and can't figure out how to remove the old blades. It looks simple enough - just lift the tab covering the slot where the arm inserts into the wiper blade, push the old blade down towards the base of the arm about an inch and lift the old blade off when the hook portion of the arm is back in the wiper blade insert hole. I can't get the old blade to slide down so that the arm gets in the insert hole. This should be easy and simple - what's the secret?
Old 01-30-23 | 11:46 AM
swfla's Avatar
swfla
There are several YouTube videos showing this.
Old 01-31-23 | 08:29 AM
DJWLDW's Avatar
DJWLDW
Shut the wipers off by turning off the engine off while they are up on the windshield. I just did mine in December. Took me forever to figure that out.
Dennis
Old 01-31-23 | 08:56 AM
swfla's Avatar
swfla
Is it possible that the current blades aren't OEM??
Old 02-06-23 | 08:50 AM
davidcvigi's Avatar
davidcvigi
No, the current blades are identical to the new blaades that I've got. Also, I have the wipers positioned upwards on the windshield by shutting off power while they are at top of wiping motion. I've looked at the U-tube videos. I've opened the insert door tab on the old wipers and tried to slide the old blade downward so the arm hook is positioned in the slot in the wiper blade, but it will only move about a sixteenth of an inch, not enough to get into the slot.
Old 02-06-23 | 09:57 AM
tx170754's Avatar
tx170754
There is something wrong with your blades, I did replace mine with OEM ones from Amazon and it was very easy to do it....
Old 02-06-23 | 10:37 AM
swfla's Avatar
swfla
Try a lubricant spray or pay a shop to do it for you.
Old 02-06-23 | 12:29 PM
WisBad's Avatar
WisBad
I might suggest just replacing the blade inserts. Pretty sure they are only about $9 - 10 bucks each from the Stealership...
Old 05-27-23 | 08:50 PM
Sherl's Avatar
Sherl
Can someone please confirm the Lexus part numbers
Lexus Wiper Blade 60Product ID: 85212-YZZ2G-LXRemove$16.07 × Quantity1 $16.07Lexus Wiper Blade 42Product ID: 85212-YZZ2B-LXRemove$16.07 × Quantity1
Old 05-27-23 | 09:18 PM
Sherl's Avatar
Sherl
Okay here is the LS460 part number for wiper blade that takes refills
WINDSHIELD WIPER BLADE (RIGHT, FRONT) - RIGHT HAND SIDE
$22.13
Qty: 1:
8521242120
WINDSHIELD WIPER BLADE (LEFT, FRONT) - LEFT HAND SIDE
$22.13
Qty: 1:
8522250080
Old 05-28-23 | 07:19 PM
DJWLDW's Avatar
DJWLDW
The Blades I bought in December for my 2010 LS460L from the Toyota dealer were:
85212-YZZ1J-TM Blade sightline 6
85212-YZZ1C-TM Blade sightline 4
The were $20.70 each.
Dennis
Old 05-28-23 | 07:20 PM
Sherl's Avatar
Sherl
Dennis
Are the rubber in them replaceable?
Old 05-29-23 | 07:53 AM
DJWLDW's Avatar
DJWLDW
Sheri
I don't know if I could just have replaced the rubber insert. It was a whole assembly so that is what I replaced. There was a right and a left. As a rule the LS does not get driven in the rain unless we are on a road trip. So that was the first time I replaced the wiper blades since we bought the car when it came off lease with 19K on the clock in 2014.
Dennis
Sherl (05-29-23)
Old 07-23-24 | 11:49 AM
7milesout's Avatar
7milesout
Dredging up an old post to say that, after 15 years, but only ~61k miles, I'm replacing the wiper inserts ... FOR THE FIRST TIME! It currently has the original wipers, blades, inserts on the car. And yes, the old inserts are tearing. The car has only been in the rain maybe 5 to 10 times.
I'm getting it spruced up for an 1,100 mile trip from south Atlanta metro, to Newport, RI where my son is in Navy OCS. Going up for graduation. It's a couple more months out, but never hurts to get ready early.
And I'm going to replace the cabin air filter for the first time also. I have to look up the procedure that prevents some tab from getting broke off. Glad I'm able to remember that. Seems like you access the filter with the system in RECIRC to prevent bending / breaking something. FWIW...
Dave144239 (07-23-24)
Old 07-23-24 | 02:06 PM
lexus13dan's Avatar
lexus13dan
Bought my wiper blades at advanced auto, was ready to go outside and install them, The man at the front counter said he would do it, took him less than a minute for both,Got the trico, Best wiperblades ever!
