SC Photoshoot, Wheels, Whatever Else Secton
Is there anyway we could add a images/photoshoot/name your color only SC/look at my baller new wheels that everyone already has seen a million times before/look at how low I got.
It's VERY hard to find information of use whenever you've got 90% of the first page alone being freaking RANDOM threads about whatever photoshoot or color of their sc only threads.
Anytime I've ever asked a LEGITIMATE question on here it gets knocked to the second page within five minutes because of all these retarded photoshoot threads.
Forum Administrator
Thanks for the suggestion, will consider how we might do that but I think it would probably require more manpower to constantly move all the threads you don't like into another forum so the ones you do like stays on top than we can possibly muster. It's hard enough just getting suspension and engine related stuff put in the right spot (only happens ~50% of the time).
The main forum sections for each model have 'trends' of thread types and sometimes they are more technical and sometimes they are showoff threads. Right now it looks about 50 / 50 reviewing the main SC forum threads.
If you're having difficulty finding information, definitely suggest you stop looking manually through the pages of the forums and use the search feature. I understand other member's active threads might push yours down the page, but that's the nature of forums.
The search feature is absolutely useless 90% of the time for me. If I search for door lock actuators and it comes up with someone's wheel thread because they mentioned LOCK once in there.
I know vB 3.7.x had issues with search. Is there any reason why we haven't upgraded to the newest revision (4.x)?
I would be more than happy to volunteer my services and after running the one and only 9th Generation Galant forums I believe I'm more than qualified. If you guys ever need someone let me know.
Forum Administrator
Search on this vB version works just fine if you qualify it correctly with expanded keywords, search in title only to narrow your search, etc. Sometimes your answer just isn't out there. I'm also assuming you looked at the door actuator threads linked in the DIY sticky thread.
I'm sure you know you can also use Google to specifically search CL with an even broader array of keywords and operators.
If you need help searching for something, PM me the question and I'll give it a shot.
Like I said, I'll volunteer my services anytime you guys need it.
Good Luck
Forum Administrator
Thanks, appreciate the offer of help.
Still think you've got the exact opposite impression about using Google to search. You can really narrow the operands more tightly and exclude items that are showing up you don't want to include
Here's a decent primer http://www.makeuseof.com/tag/master-...god-save-time/
You can do a good bit of it easier via menus using their advanced search form http://www.google.com/advanced_search
Put in the CL forum (https://www.clublexus.com/forums/) as the site you want to search in, and also add sc300 sc400 as words you want to include (in addition to your primary keyword) which will narrow your results primarily to the sc forums. It'll string together the search for you:
http://www.google.com/search?q=%22do...fe=images&tbs=
Once you mess around with it a bit, you'll find you can do a lot more detailed searches than you'll ever get with a native vB search on any version. If the answer exists and you know the keywords, you can find it.
Forum Administrator
Thanks, I'll stop trying to educate you then Just sounded like from some of your replies that you weren't taking advantage of the technology or didn't know how.
I guess you've got it well handled
I've always used Google over built in search functions but 90% of the time I'm on my phone, covered in grease, trying to resolve an issue quickly and it's clunky to use the search - but like I said, that's mainly due to people not tagging their threads / titling them appropriately.
