Problem browsing threads
Over the past few days, I've been having problems browsing the threads. Clicking "Next Thread" may bring me to the next thread, or may bring me to a thread that last had a reply a week or even a month prior.
Is anyone else having this problem?
Seems as though ClubLexus forums is having a transmission failure...
Forum Administrator
I'm not sure what the 'next thread' feature is you're talking about... maybe something I never use.
But if something is acting screwy for you, try this as your first step... close all your browser windows except one. Log out of Club Lexus and clear your browser cache / cookies, then log back in.
When reading the threads, clicking the "next thread" button, right above the Posting Rules.
I've done everything that you've asked, but the problem still persists. I was just curious if anyone else was experiencing it (thus far, I've only experienced it in the RX First Generation forum).
Thanks
Thanks
Forum Administrator
Dan,
See the feature and tested it in the 1RX forum, but worked fine for me.
Next time you see it specifically do it on a thread, step out to the forum threads list and see if you can recreate it again. If you can, post up here and tell me which posts you see it happen on so I can try it as well.
Thanks
Thanks
Ok, here is an example of the issue.
In the 1st-gen forum, there are the following threads, from most recent (reply) to oldest:
If I'm in thread
https://www.clublexus.com/forums/rx-...coming-on.html
& click Next Thread, I should be brought to the "Code 441 - why?" thread.
Instead, I'm being directed to
https://www.clublexus.com/forums/rx-...y-problem.html
As I stated earlier, this problem has recently started, and seems to just happen to me in the RX 1st Generation forum.
I hope this helps...
Code:
running not to well, i have codes (need help) jevanof Today 07:42 PM by jevanof 4 38 Where are side airbags? lserlohn Today 06:43 PM by salimshah 1 11 99 RX300 180K miles, should I buy? bula Today 06:03 PM by bula 3 35 RX300 OEM roof rails martinb820 Today 04:26 PM by jasonodsky14 1,597 2nd code ever: 1155 Bank 2 Sensor 1 Hatchman Today 01:17 PM by Hatchman 0 17 Code 441 - why? JAB Today 11:07 AM by JAB 9 110 2001, 300, abs, actuates, brakes, coming, hitting, motor, rx, slow, speeds 2001 abs keeps coming on (Multi-page thread 1 2) KimShep7 Today 08:28 AM by KimShep7 15 451 Question about compatible nudge and nerf bars Australian Today 06:10 AM by Australian 3 62 stall incline starting 01 RX300 - problems starting if left on an incline Will49 Today 01:01 AM by Will49 0 31
Forum Administrator
Thanks Dan - perfect. It works exactly as you expect it to for me (when I click next thread it takes me to the Code 441 thread) so suspect its something on your settings.
When you look at the forums page for the 1RX sub-forum, what are the options at the bottom under Display Options?
Sorted By (Last Post Time?)
Sort Order (Ascending?)
From The (Beginning ?)
Also, under your user control panel, options https://www.clublexus.com/forums/pro...do=editoptions
in the "Thread Display Options" section what does these values have:
Thread Display Mode (Linear - Oldest first?)
and
Default Age Cut Off
and
Default Age Cut Off
