test
bluelex,
Just a heads-up for you. ClubLexus has recently instituted specifications regarding signature size and content. Signature constraints are as follow:
1) No images physically larger than 450 pixels (wide) X 100 pixels (tall)
2 ) Image file size no larger than 50K
3) A maximum of 8 lines of text, including blank lines
4) No advertising URL's in signatures unless you are a ClubLexus sponsor
When you have an image file that is the proper size,
try using IMG in your tags instead of IMAGE.
450x100 pixels or smaller
50K or less
The image you are attempting to use is 640x480 pixels.
It's too big. Do not use this image for your signature.
50K or less
