So what happened to the my posts at the top?
I see new posts, search, used cars???? How can we find our posts we did?
You can delete this post if its in the wrong spot, or I will do that. Now if something is moved we won't find it, well the "My posts" deal didn't last long enough either.
just hover the mouse over your name at the top right and the 5th button down is "my posts"
Forum Administrator
![](https://www.clublexus.com/forums/images/ranks/rank-admin2.gif)
For the specific retired 'my posts' feature which I also used heavily, unfortunately it had to be removed because the unsupported plug-in that enabled the feature created some conflicts with the update.
HOWEVER you can build your own if you want (which is what I did). Bookmark it and put the URL in your browser bar favorites so it appears where you can easily click on it
I've pasted in the link aligned with your 'user number' below that does pretty much the same thing as 'my posts' in the last 7 days.
https://www.clublexus.com/forums/sea...1&searchdate=7
