order and logic
order and logic
when you type in sc 300 for information you get every model which was not what you ask for! why not stick to the model you asked for. instead you have to surf thru hundreds of comments that has nothing to do with your model. it should be you type in the model and the area you are asking. try it! type in sc 300 bulb replacement hi beam and see what you come up with I would really desire more logic and order for a persons stated problem
Keeper of the light
Its not an issue if you know how to search properly. Many tips were put in a thread on how to do so. Just..... do a search for it.
anyway searching any internet brand forum is no trick. Wildcards will improve your search. This isn't information specific to club lexus. It's interweb wide. I'd google search tips about wildcards so you get a chance to find things you want.
speaking of order, ironically, this post is about searching not a vehicle model so it goes in site suggestions.
Forum Administrator
Couple of other suggestions
You might find what you need in the 1SC FAQ without even searching
https://www.clublexus.com/forums/sc-...tart-here.html
Sorry to be blunt, but you clearly aren't using advanced search or aren't using it right.
Using the generic search will get you every single keyword in every forum. Under the search dropdown, select advanced search
https://www.clublexus.com/forums/search.php
Then off the right you'll see Search in Forum(s) and that's the place you'll select the SC 1st gen forum. Then put in your keywords, etc. and you'll only get results back from the first gen SC threads.
XeroK00L
Site Suggestions & Problems
01-10-05 10:30 PM
