Site Suggestions & ProblemsBring up any suggestions, questions or problems concerning ClubLexus. If you need to test a forum feature, post here too.
Note - questions about your Lexus do not belong in this forum!
I’ve experienced this for quite a while here where I post something and some of the words are duplicated. I also see it happening with post on this forum from other members.
I can post a reply like this and experienced will show as “experienced experienced “
My grammar is poor so I use spell check so could be related? Example of a recent post.
I don’t know. I often go back and review my post when I am bored and that is when I will catch it and edit. I post on both devices equally so not sure.
I will pay more attention to this but it doesn’t seem to just be me.
The editor does not have the ability to alter text that isn't marked up. Meaning, the software does not change what is typed into the message area. It does run a script to replace text that needs executed (such as formatting - bold, italic, etc.,) but that is isolated to certain commands that invoke the process and it's also technically not replaced as it's altered on the fly. The editor does not have any built-in spell checker.
In short, the editor cannot change your "experienced" to "experienced experienced" as there is no spell check on this side nor is there any code that would change words typed into the editor. That would be done locally by your browser - such as a spell checker.
In that regard, the likely issue is the software you're using for spell check. You will need to disable the software and re-test. I suspect the issue will disappear.
