Subscription Options
There does not seem to be a way to disable thread subscriptions when you reply to a topic. There also does not seem to be a way to disable weekly summaries of any forum you have subscribed to. Honestly, I dislike spam...why do you insist on sending spam?
Your default Subscriptions are set in the UserCP: https://www.clublexus.com/forums/usercp.php
Edit Options: https://www.clublexus.com/forums/pro...do=editoptions
You can set the default Subscriptions from Do Not Subscribe, No Email (so it appears in your Subscribed section but no email), Instant, Daily or Weekly Email.
That controls the Default behavior - going forward.
You then can customize the Subscriptions, per thread, by overriding the Default setting in the UserCP by using the Thread Subscription Notification Type (below the message reply area):
That controls the setting for just the thread you're replying to.
To change previous Subscriptions, you must go to the Subscribed section:
View Subscribed Threads:
https://www.clublexus.com/forums/sub...n&folderid=all
This contains a master list of all your Subscriptions. If you want to change previous Subscription settings per thread, you can select (Mass or Single) threads then change the Subscribed settings:
Finally, there is the option to subscribe to an entire section (forum) by using the Subscribe to this Forum link under the Forum Tools menu. Note this is not by default so you would have had to opt in for this Subscription. To Unsubscribe from a section that you've Subscribed to, you need to visit the section and then under the Forum Tools menu you will find an Unsubscribe from this Forum link.
