Supra Bilsteins work great!
It wasn't enough to just put on a set of Supra lower control arms,I found a leaky shock,replaced them with Bilsteins for a Supra,WOW!
What a difference,lowered the car another 3/8" too,along with the 1/2 lower that the stock Supra TTsprings had already provided,it makes for a decent ride height,pretty smooth ride considering how well it handles.
They cost a hundred $ a piece,alot less than oem Supra TT @ $155 each,rears are the same cost.
No pictures, they look just like stock,but are yellow.
I took it all back apart again,the ride was too funky with the lowered ride height,the control arm angles/geometry was too lame for the way I drive.
It plants even harder now ,rides great, so I'm happy with the extra wheelwell gap, it's still lower than stock Lexus height.
The Supra control arms are a direct replacement for the SC ones,cost under $200 each, the real problem was that the parts (spring seats) that came with the Bilsteins made for a 1" lower ride height. The problem was fixed by using the stock Supra spring seats.The spring seats slide over the top of the shocks and are tapped into place w/a hammer.
Car's only a half inch lower than stock SC,not much but gets it out of the 4wd category anyways.
I would have set the car up lower had the suspension pivot points(on the car's chassis) had been lower, but that's as low as it will go w/out sacrificing the suspension dynamics IMO.
