bleeding of brakes
bleeding of brakes
can someone please give me the correct way to purge the system of current fluid to be replaced with racing brake fluid once i reattach the stainless steel lines to the new supra calipers
someone once told me that the gs has to bled through a machine because of the abs system
the correct procedure for bleeding is what???
The "proper" way to bleed the GS brakes is with Lexus computer that opens up each ABS channel. However I have bled the system successfully with just turning the key to the ON position so that the ABS pump is activated. I then bleed using the normal standard method using a 1 man bleed kit. My brake bleed siphon pump does not work very well on the GS.
98SBF
Suspension and Brakes
11-13-08 09:28 PM
