97 aristo with supra brakes ??? HELP!!!!
1st Gear
Okay so I have a 1997 toyota aristo I already installed fromt oem supra calipers/ebc rotors and they simply just bolted right up with no issues (minus removing dust sheild ) but I'm trying to put the rear ones on now and I noticed that the rear supra calipers bolt holes don't even come close to bolting up and I was wondering does anyone know if someone makes a bracket kit to make the supra calipers fit ? Or would I need to get knuckles ? Or what do I need to do in order for them to bolt on /fit/work ?
For the rear I used LS430 rear calipers/pads with supraTT rotors (known swap). I linked the "XAT" brackets you'd need. Unsure about supra caliper fitment in the rear though. I did the LS400 swap in front.
https://www.suprastore.com/xatra2gsrebr.html
lexo101
Suspension and Brakes
01-23-13 06:03 PM
