SC430 front lower rear control arm bushing
Anyone had these pressed out and replaced? Mine have p/n 48655-24060 on the bushes...the centre sleeve is 19mm on the side that goes up against the floor and 14mm on the side facing the ground. Febest have a bushing TAB-177 that may fit but they can't cross ref with my chassis number UZZ40-9010522
Mine have the same number but every inquiry so far has not found this odd part number. Getting them pushed out now so can measure accurately. Febest TAB-185 could be the size,.https://size.name/en/products/48655-30170
https://size.name/en/products/48655-30170 shows bush 48655-30170 as the perfect fit for size 65mm dia, bush length 35mm, internal sleeve 14 lower end, 19.5 top or floor end, 65 mm sleeve length.
Jap Euro Car Parts have 65mm bush that is supposed to fit, Part JE09355 GBP22.00, shipping is expensive.
I'll post again when I have the bushes out of the arms.
Bushes out..hole size is around 64.93mm pic attached
07 SC430 front lower control arm bush sizing.
jtwags
06-02-14 12:34 PM
nthach
08-23-09 11:14 PM
