07 Is250 Hydro brake and ABS
5th Gear
curious if anyone has installed a hydro brake on their 2is and I want to know how abs handles the rear wheels locking up while the front keep spinning. ordered everything and I plan to tie into factory abs and brake system but some abs systems don't like sensing speed from the front tires and not the rear.
I can say that spinning both rear wheels via 1st gear into LSD, freaked it out and applied brakes and cut throttle. I suspect the same is true of fronts rolling while the back is slower or stopped.
Do i detect drift application? If yes, you'll have to disable VSC.
5th Gear
If you're stopped it won't know a thing.
yes VSC is already disabled and you would be correct. I'm drifting this car. thanks for the info.
5th Gear
250 with 3.0 swap and brz diff. is350 throttle body, e85 tuned and pretty much everything you can do to one. traction control is turned off and vsc is turned off so I'm thinking the hydro brake should work fine. if I have to delete the abs I guess that's my only other option if it still gets hung up. got a drift event in 2 months I'm really trying to have everything done. guess the only real way to test it is to try.
xbladex00
05-07-15 02:10 PM
