is350 rotors rubbing inner wheel bearing
9th Gear
Why do things never go smoothly for me. The rotor is hitting where the wheel bearing bolts in. Any advice? Should I just sand down either the rotors inside or try to sand the wheel bearing down a bit? Nobody else has had this issue apparently.
2006 Lexus is250 AWD I bought is350 AWD rotors+pads. I don’t think there’s a difference but I did it to be safe
9th Gear
2006 Lexus is250 AWD I bought is350 AWD rotors+pads. I don’t think there’s a difference but I did it to be safe[/QUOTE]
[QUOTE=2isdb;11751958] IF ANYBODY HAS THIS SAME PROBLEM 09-13 USA SPEC ROTORS FIT AWD 250 Jeff Lange in another forum coming in clutch I was able to matchup part numbers with NAPA and get duralast through autozone if anybody wanted to go the aftermarket route here’s the duralast part numbers
LEFT- 44675
RIGHT- 44666
different part numbers for left and right due to directional vents
SerigoR
03-02-20 11:08 AM
