Front brake pads is350
Old 08-31-24 | 03:26 PM
GrizzlyMan's Avatar
GrizzlyMan
Default Front brake pads is350
l may sound like a silly question, but man I have spent about half hr online and cannot really find a clear answer so decided to post here, my apologies if it has already been gazillion times asked before.
I have a 2012 is350 F-Sport, need front brake pads soon.
Went to eBay and found the brand Akebono, it states enter the vehicle and for is350 is the base line. From my understanding isn't the F-Sport bigger/different calipers?
​​​​​The same goes for AutoZone, Advanced Auto, for is350 is bade model. Unless, it is after all the same calipers regardless of F-Sport or not.
According to Lexus online stores it is ptr0953111, for $160ish or so.
Old 09-01-24 | 09:47 AM
mike33's Avatar
mike33
The is350 uses the same calipers (Advics 4 piston) on all models F-sport included.
They did offer an aftermarket 6 piston caliper (big brake kit) which they sold as an F SPORT performance accessory.
GrizzlyMan (09-01-24)
Old 10-06-24 | 08:08 AM
GrizzlyMan's Avatar
GrizzlyMan
The brake pads provided by Lexus and any online store, had this shim that runs the full back face of the pad, glued to it, not placed. I am not sure if it is a revision, or they are saving in production stating it is for all models. My original pads had a slanted groove and the shims were halfway on the pad.
Original pads have an angle, shims run halfway, not all the way to the edge.
I had to cut all the end L tabs as that little bit of metal would jam the pad in the caliper channel.
I ended buying Detroit Axle, I compared them to Lexus, exactly the same, and pictures show BOTH Detroit and Lexus do not have the angle edges, and do have the shim full edge to edge.
With the Dremel and a file, cleaned up all the rough edges, no high spots, pads move smoothly in the calipers without getting pinched.
Impressed w Lexus, not a drop of rust anywhere, this is the final result. One of the pin locking wires broke, so I used HD rc body clips had extras from my ARMA Notorious. No sweat as the front uses body clips.
One of the wires broke (rears), and the one in the kit is not the same.
Extra misc photos, barely running metal to metal....
Old Today | 10:35 AM
2013FSport's Avatar
2013FSport
Received 1,536 Likes on 1,278 Posts
Idk what part number you used for that shim, mine dropped in without issue. And ya, 350s all use the same caliper F or no F-Sport.
04945-30350 SHIM
47748-22460 ANTI RATTLE
04465-30450 PAD
sirdizzle
11-21-18 09:11 AM
suginathan
Suspension and Brakes
11-08-17 06:51 PM
15Atomic
07-14-17 04:43 PM
bazzle01
03-12-17 08:16 PM
Carlos9321
02-06-15 04:06 PM
Quick Reply: Front brake pads is350
