AGX struts & Eibach Springs
I am planning to put on a set of Eibach Springs and KYB's AGX's. The concern is they only application for the AGX I have found is for the TT (94+).
From what I have read it should not be a problem. Any comments?
Thanks for your help.
i am curious about the same thing.....?
will the adjusatble agx's work on a sc300.....i've seen profiles where people say they use the agx's from supra's, but i haven't come across anything saying it requires custom work............
any help would be appreciated...
The adjustable AGX's for the Supra will fit the SC, but you will need to use the Eibach springs for the Supra as well. The difference is the way the rear spring fits onto the shock.
I'm running this setup with the TRD sway bars and just LOVE it!!!
it will fit flawlessly.....no modifications.... i don't have a sc, i have a is,
but does he buy supra tt parts
or supra na parts?
could he use other springs for the supra other then eibach...i only see the pro kit for his car...not the sportline....do they make sportline that would work?
thanks in advance....
Originally posted by ali1983
so my friend buys supra agx's, and supra eibachs for all four corners (front and back)
or supra na parts? [/QUOTE]
Either will work. The TT springs are slightly stiffer. I have the TT springs and with the AGX's on the softest setting, it's only slightly stiffer than stock but still a very "plush" ride.
could he use other springs for the supra other then eibach...i only see the pro kit for his car...not the sportline....do they make sportline that would work? [/QUOTE]
Yep, any springs as long as the shocks and the springs are for the same type of car.
I don't know about the Sportline springs. Check the website, or contact the manufaturer directly to get the authenticated answer
thanks in advance.... [/QUOTE]
Glad to help.
