Will any big brake kit fit me?
will any of the many big brake kits fit a +44 20x8.5 front wheel? i don't think so but mayb some can just assure me 2 end my pipe dream
![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
The One
I'm not as quick in terms of figuring out offsets. Can you measure the distance from your stock rotor to the back of your rim and from the rim hub to the back of your rim? I have some of the templates so that we can see if things will fit. Better yet, you can download the templates from the manufacturers' websites and try them out for yourself.
If you wheel is not high disc, your only options are StopTechs and Rotora. If the StopTechs fit, you can have 14" or 13" rotors. (I'd try the template for both just to make sure.) With Rotora, you can only have the 13". Rotora have a 14" kit with 6-pistons but they need even more clearance space. The AP racing brakes actually need less clearance than the Rotora 6-pistons. Brembos and TRD/Supra/RMM/... are huge. I did not even look into other systems like Endless since too much $ for me.![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
Like I said, I'd start with StopTech and Rotora. A, your car deserves some big brakes if you can manage it.
you talking about your zeuber? wont' fit man, yours is either low disk or med disk, so ap racing, endless, brembo, supra tt they are all out. stoptech 13" and rotora you might be able to fit but still need to check the clearance.
and the offset really has little to do with the fitment. but in general with 44 you pushing the wheels so much inside, chances are even smaller. my 19s they are +38 in the front and it's high disk and i only have like 2mm between spokes and my calipers
My 19" fronts with +38 high disc have TONS of room though. I probably still have 1/2-3/4" to the StopTech calipers with 14" brakes.
Originally posted by bitkahuna
Right +44 and especially if not high disc has little chance of clearing big brakes.
ya guys i was talking about the zaubers, i kinds knew it wouldn't fit but figured i'd ask 2 b sure..thanx...i went with normal disk upfront cus i wanted a nice lip up ther as well..i thought having a superlow in the rear 4 huge lip and a high upfront withsuch a small lip would look weird
so well i have do just stay with what i have i guess...4 my next set of wheels i will definetely b gettting a front wheel that can fit a 14" brake kit ...hopefully by summertime if everything goes well....thanx again guys.....
Ed...sorry man i haven't called its been a hectic week starting 2 move my furniture 2 the new house i closed wed. so i've been really busy...i'm doing some pre-painting b4 i move everything over..hopefully by next weekend i'll b done...mayb we can get those daizen sways in..everyone is telling good things about them...
The One
well don't give up yet man
how much spacing do you have between stock caliper and the spokes now? if you got say 1 finger i think you will be able to do the 13" stoptech kits. it fits the stock 17s so tight so you might have a chance
I've seen GSTRANCE's 20" Zauber Gettin's. (Look awesome by the way.) NO chance of fitting brakes like mine, and I highly doubt they'll fit the 13's either, since they're so close to the stock calipers. But maybe bluelex's are different fitment.
But as you guys said, bluelex - StopTech has the printable templates on their web site, which I used before getting mine - good for peace of mind.
it was almost good news till bit reposted
j/k i have the same offset and size as gstrance up front....i will buy a tape measure this weekend and take some pics with the inches availble if any...guys thanx 4 the intrest and help...
welli got around 2 measureing how much room i have left and its a whole 1/2 inch, actaully a little less..
i reallt don't want 2 do spaces i've heard bad things and have been told 2 avoid them if possible...here is a pic..
