I want to LOWER my SC300
Greetings.
I have a 1992 SC300 5-spd. My goal is to lower the car only a small amount, perhaps 1 inch and to maintain the stock ride as much as possible. Ideally the car would ride exactly the same and be 1 inch lower - not sure if that's possible obviously.
Anyone have recommendations for how to best accomplish this?
Thanks.
Thanks.
I would suggest Eibach Springs for a cheaper setup...You will not achieve the same ride quality as before...You'll feel more of the road...
If don't have a budget...You can get a full Coilover suspension...Tein CS or JIC Magic...Do some research on these...Plenty of info on coilovers if you do a search..
Good luck..
Good luck..
Good luck..
Good luck..
https://www.clublexus.com/forums/sho...threadid=97872
I did do a search and had trouble finding info on the lowering setup that best replicated the stock feel. Most people seem to want a firmer ride, which I don't.
I'll look into the Eibach's, but if you have any other suggestions, I'd like to hear it. I really don't need to go all the way to a coilover, seems like more than I need.
thanks.
thanks.
i'm interested in keeping the stock ride quality while i still reap the benifits from tein cs coilovers 1" drop(due in a few days) and poly u bushings front and rear (rear due for install soon- after bodywork). the front install left the car feeling extremly tight and responsive ,it felt like a could confidently do a turn @70mph! and the car would remain stable,but it seems like doing the front upper bushings caused more road noise.
Do a search on Sway Bar bushings and Control arm bushings...
I'm also well aware of coilovers and all those options, I'm just wondering what the softest lowering kit available for the SC300 is. I'll just assume it's the Eibach kit since I haven't even found another manufacturer for SC300 lowering springs. Unless someone has any other ideas?
Thanks.
Originally posted by ddbitt
Greetings.
Thanks.
Greetings.
Thanks.
-Steve
Mortgage Slave
I just didn't understand why they would help with keeping the ride of my Lexus nice and plush.
A 1 inch drop will not even show. The car will still look like it is at stock ride height.
Putting on Poly U bushing, at least from what I know of my years of racing experience, stiffens up the ride of a car, which is not what I want to do, and will increase noise, vibration, and harshness.
OneHot: Well either way it sure seems like you guys like the bushing swap, so I'll take your recommendation on that one. If the poly U bushings didn't make the ride rougher, etc. then obviously it's the best way to go. I've just known people to do that mainly for performance, not comfort.
BTW, are you all bringing up the bushings because it's easy to swap them during the spring installation? I have a bushing service kit for installing them so it won't be a problem, I'm just wondering why you brought it up.
Thanks again. I appreciate everyone's help.
I'm loving this car more and more. I like the engine more than the engine in the G35 I was thinking of buying.
Aaron
It is to my understanding that the control arm bushing installation (front and rear) is around a 5-6 hour job and sway bar bushing (front and rear) install is around 20-30 minute job..
Well, if you have several mechanics installing your bushings and springs at the same time then I doubt it will take that long..
