should i cut my springs???
Old 12-25-03, 01:48 PM
lsportlex
lsportlex's Avatar
Default should i cut my springs???
i have H&R springs in my gs4 but i dont like the fact that it is noy low enough, i was thinking about cutting off half of a coil just to make it lower.....Should i do it?? Will i cause a problems???
Old 12-25-03, 02:03 PM
DaveGS4
Forum Administrator
DaveGS4's Avatar
Received 2,268 Likes on 1,377 Posts
No, IMO you should not.
Cutting springs can make for a very dangerous and unpredictable suspension.
If you want lower, sell the springs you've got and get another pair, or go for coilovers.
Old 12-25-03, 03:08 PM
LXOGOOD
LXOGOOD's Avatar
Like Dave said, NO. By cutting the springs, even a half a coil, will cause your front end to be very bouncy. Since the GS is very top heavy, it will put to much pressure on the springs/shocks causing premature wear on them. I know this because with my very first eibach spring setup, the shop cut a half a coil to get me lower in the front and it drove like hell. Plus, since I have HID lighting, it was bouncing all over the road at night. Not a good or safe setup. My advice is to either get different springs, larger wheels or do a coilover system... Take by advice....
Old 12-25-03, 04:06 PM
GS4Will
GS4Will's Avatar
BIG no...no...spring are not that expensive, invest in another set/or coils, and sell your HRs..
Old 12-25-03, 07:58 PM
lsportlex
lsportlex's Avatar
much thanks for the advice fellas.......but i kind of didnt want to do coilovers.....i thought the ride was horrible, i had the tien coilovers..is there any springs on the market the make the car about 2 inchs or so lower???
thanks again davegs4, lxogood, gs4will
Old 12-25-03, 10:50 PM
HKGS300
HKGS300's Avatar
Ride terrible?
It depends on what type of coilovers you get.
For instance, Tein has many different flavours, like SS, HA, CS, Flex, RA, ...
All of these are differently priced, and are differently tuned.
I have Apexi WS coilovers, and I think that my ride is pretty much close to stock. I used to have KGMM springs and I hated the ride, too stiff.
Old 12-26-03, 02:17 AM
rominl
exclusive matchup
rominl's Avatar
simply put, no....
Old 12-26-03, 08:16 AM
bluelex
bluelex's Avatar
i have the teins cs coliover and the ride is almost stock ...not counting tire sound or low profile feel but the ride rom the coilovers themselves is great...i would also not cus the spring..good luck
Old 12-26-03, 08:28 AM
lsportlex
lsportlex's Avatar
thanks to everyone for the advice....
Old 12-26-03, 09:04 AM
lexforlife
lexforlife's Avatar
lsportlex
by no means cut those springs , vety dangerous and uncomfortable
if you want lower go with Daizens new true progressive rate spring front drop is 1.9 and rear is 1.7 very low indeed and tighter spring rate vs ltuned/eibach
Old 12-30-03, 09:06 AM
hitechgs3t
hitechgs3t's Avatar
get the lsportline spring
Old 12-30-03, 09:44 AM
lsportlex
lsportlex's Avatar
isnt the lsportline spring made by eibach?? so i figure that eibach is not that low so lsportline is not that low.......
Old 12-30-03, 01:06 PM
LXOGOOD
LXOGOOD's Avatar
I would personally go with the Daizens... However, make sure you upgrade your shocks. By lowering your car more than an inch, you put more stress on the shocks. The stock shocks will probably blow out within 6 months.
Old 12-30-03, 02:52 PM
rominl
exclusive matchup
rominl's Avatar
very true, the stock shocks are weak against lowering springs
Old 01-14-04, 11:03 PM
SandRock
SandRock's Avatar
The EDFC does not adjust height.
bigwes
Suspension and Brakes
13
12-05-12 08:11 PM
KickItOut
16
08-21-12 01:08 AM
edgeucated
07-12-12 01:03 AM
lmn8
SC- 1st Gen (1992-2000)
58
10-19-10 11:42 PM
99gs713
09-03-10 02:23 PM
Quick Reply: should i cut my springs???
