Rear Control Arms
Which rear suspension bushing is likely to have the brunt of the wear and tear? Is it like the fronts where the lower bushings are usually shot while the uppers are ok? Looking to replace these and would like to know which ones will most likely need replacing: lower front, lower rear, and/or upper arms? Thanks.
Mortgage Slave
Same deal here... I have just recently replaced the rear upper control arm as it was seriously about to fall off (one tap on the rear upper and it'd come loose from the rest of the suspension assembly. The ball joint (or thread connecting to the balljoint I can't remember) was so bad that the thread actually smoothed out so it wasn't connecting to anything.
Bushings are cheap (relatively) compared to the cost and effort of getting them replaced and getting it re-aligned. I'd just go ahead and replace them all at the same time.
![Confused](https://www.clublexus.com/forums/images/smilies/confused.gif)
