So sometimes on the freeway at around 60-70... I'll notice the car pull slightly into a direction and back the other way. I'm not sure if its the road i'm on or what.
first and foremost get an alignment. if you cant let go of the wheel on a straight road and have it stay straight, at least one of the alignment parameters is out.
i'm pretty sure it's not the alignment... it drives straight fine
i can keep a firm grip on the wheel and you'll slightly feel it pull to a side... you'll try and correct... and it's as if it over corrects... somewhat kind of like loose steering
