Are H&R 5mm spacers hubcentric?
The One
It has to do with load bearing and centering of your wheel onto the car. you know when you mount your wheels to the hub, there is a lip where the wheel attaches to the hub. This method uses the hub to center the wheel. To contrast this, if you are not using the hub, then the other way to center is on the lugs. I think it is better to be hubcentric then lugcentric.
Anyway, back to this discussion. The 15, 20, and 25mm spacers have a little lip built into it. This allows the wheel to mount using that lip. The 5mm is just flat. H & R is counting on the fact that the 5mm is so thin that there will be enough of the "stock" hub entending past the spacer for the wheel to mount.
Personally, I don't like that they made that assumption but what can you do. I hope this was clear enough.
Master Thread Closer!!
Guyz -
Sorry for chiming in late on this thread.
GammaLex - to answer your question...I got both on...spacer and centering rings. I have NOT notice any shake or shimmy any speed for me. I've gone up to 90 mph on the highways here...albeit the roads aren't the smoothest (dang potholes on the highways too) ....but when I'm lucky enough to find a smooth paved road...I pay attention and look/feel for any vibrations....so far ...NONE.
Neo - Yah...I got the H&R 5mm spacer on my rears....it pretty thin and very flat...no lip like the 15mm + sizes. With that being said...there was still enough lip from the OEM hub to mount my wheels (with centering rings).
Hope this clarifies things.
Pete
Pete
Originally posted by LEXISM
ok so were can I buy my 5mm spacer? wher do you guys recommened and for how much? thanks
Erick
Erick
http://www.optauto.com/webstore/prod...k=yes&dept=421
Pete
Thanx Neo and PHML. OPT auto salon is out of the 5mm spacers till end of march early april. I guess that means another dealy for my coilovers and big brakes
![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
The One
Although there is no lip on this spacer, how well does it fit around the original hub? Is it a nice fit (roughly 60mm opening) or is it like the generic spacers where it is meant to fit any hub (large opening) and is using the lugs to be kept in place? Were there additional hardware: longer lugs/studs, bolts, nuts, ...?
I am trying to determine if these H & Rs, although not hubcentric, are still specific to the Lex or are we paying extra for the H & R branding?
Originally posted by Neo
More questions Pete.![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
It fits around the hub loosely....more like generic. It came with longer stud bolts...but I didn't use them.
I torqued each lug/lock to 105 ft/lbs to ensure its tight. I read other threads that recommended torque was like 75-80 ft/lbs...but I felt that was too loose.
The One
Thanks for the info. Please check PM.
The Rotora 13" kit. It was smaller then the Stoptech. With the Stoptechs I would need about 8mm more to clear, the Rotora only needed 3mm. Weird huh. I also have the HKS LS+ and UGO front and rear STBS to go with it.
The One
It is kind of funny that their 4-piston setup is that "small" but their 6-piston is huge, bugger than the APs and if I remember right also the Brembos. At least this was my impression from their preliminary template. Did you have a problem with the Rotora template not being to scale?
