Will supra TT suspension / brakes fit?
I was wondering if the Supra TT suspension and brakes will fit an sc300?
Another question: If I do the GTE conversion and use a supra downpipe, can I use supra TT exhaust?
from what ive heard suspension parts from a supra will swap over just fine. There are many members running at the very least supra shocks/struts. Coilovers should follow.
On the squeaking issue, it may not be the shock/strut combination causing it. Look into the state of your control arm bushings. From experience with the supra, the squeaking/creaking sound that is really loud and annoying is due to worn out bushings on the control arms. There are a few options to alleviate this on the sc without having to buy a whole new control arm.
What are the other options to alleviate the squeaking issue? I was planning on getting front and rear Supra control arms from Curt, the Tein HA or FLEX coilovers or the JIC SF-1, and an alignment. This is quite a bit of money
![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
Now I just have to figure out what the "thump thump thump" noise is when I make a sharp turn at a very slow speed. I'm hoping that an alignment will solve the problem. I only had this problem start after I put on the Supra TT wheels.
Thanks,
-Brian.
If i were to change the stock sc3's shocks/struts to supra tt stocks , would i need to change to supra tt upper mounts too? I need to double check, i'm getting these soon and i want to know if i'll need to replace the upper mounts too. Thanks.
After doing a bit of searching, it seems the lower control arms from a Supra TT do **NOT** fit the Lexus SCs? Apparently the length is a little short, because the Supra subframe is a bit wider?
What's the definitive answer on this? Anyone know? Please?![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
Thanks,
-Brian.
Thanks,
-Brian.
