Tuning your Teins???
exclusive matchup
the edfc installation powerup sequence is an interesting one, i have no idea coz' i don't have one. but if that's the way it works, then that means the tein HA doesn't come at stiffest then.
i didn't touch my flex when it first came so i don't know what it's like though
The One
Northern California Regional Officer
You guys both know I have a Manufacturing / Engineering / Quality background, so I have a lot of input about this.
I won't bore people on the forums with it, but like I said, we can talk about it offline then post when we have a consensus.
Henry and other CL members will be meeting up with me this Saturday so we can talk about it at length.
I will bring my fender mod tool when we meet up, just in case someone needs more convincing of my position .
Former Sponsor
Seriously though, this is a great thread, I dont even have Teins, and I'm interested in the outcome, just as a point of reference. Also, with the large amount of Tein owners that we DO have, this may warrant a sticky once resolved!
on the flex (for the gs) you can do it without taking off any suspension for sure, tried it before. just loosen the lock, and turn the shock no problem
We may not be talking about the same thing.
With the TEIN Flex, you have the ability to change the ride height, without touching the spring perches, thus, keeping the spring tension the same. You do this by turning the shock, not changing the position of the spring perches.
Are we talking about the same thing?
Consensus
OK,
after face-to-face discussions with Neo, Rominl, RMMGS4 & Jawnthen we have concluded and confirmed that the "Proper" way to adjust All Tein coilovers is to first rotate the thumbscrew fully clockwise until it stops. This is defined as 0 = Hardest Setting. If you would like to verify this for yourself, look up the pdf manuals on the Tein website.
When adjusting manually, turning the thumbscrew counter-clockwise 16 clicks will be 16 = Softest Setting.
When using the EDFC, during power up, it will automatically calibrate all four coilovers by rotating the needle valves clockwise until each stops and is fully closed. (0 = Full Hard) This is also know as return-to-origin mode. From that point it can be adjusted to soften the dampening by 16 incremental levels (or 32 levels if configured to that resolution).
Note that in the past, many members have posted and defined 16 as equal to Hardest and 0 equal to Softest. This is un-intentionally mis-leading and contrary to what the EDFC values indicate. There are probably several reasons for this mis-understanding to occur. Whatever the case may be, one should not be confused by this interpretation.
Just remember that full hard is fully clockwise and full soft is 16 clicks counter-clockwise. Whether you choose to define the full hard / soft settings as 0 / 16 or 16 / 0 is up to you, but we suggest that you follow the hard /soft settings as 0 / 16 respectively, which is consistent with the EDFC read outs.
The Great and Powerful OZ has spoken !
The One
Re: Consensus
correct me if Im wrong, but doesnt the manual say to be sure to not go over a certain amount of turns clockwise at risk of damaging the valve assembly. Its been awhile since I have read it, so I cant remember how many turns it was...but I do remember it saying dont go past it. Thats why in the past people have said to turn the **** all the way to the softest setings, then adjust harder from there.
Am I imagining this?
The One
exclusive matchup
however with the info from neo and rmmgs4 about how the edfc works (it initialize by going all the way to shiffest (clockwise until it stops) and then count backward, we went into an indepth discussions.
i went ahead and checked the manual available online (tein.com), and to my susprise, it says turn it all the way clockwise to FULL stiff and count 16 backward for softest, and don't get past 16 clicks
that's why now i strongly believe the manual was wrong in the beginning. too bad i don't have that manual anymore
They definitely changed it on line then...the original manual that I had was downloaded from their web site, and I know it said dont go past "X" amount when tightening them up. I wonder how many people out there damaged their coilovers by following their old directions.
exclusive matchup
