So whats the deal with rear control arms?
Will supra control arms fit the rear?
Also... does the ride quality become harsh if I were to use Daizen for the rear control arm bushings?
I just spent 400 on new supra lower front control arms and about 275 for vlamos upper control arm bushings... i am running out of money just on maintenance quick...
does anyone know if its okay to have daizen rear bushings and soft/stock bushings for the front?
You're about to find out (the rear daizen bushings - give me two weeks).
Sure it's ok to have stiff rears and soft fronts. Your car will be relatively safe (understeer).
That's impossible. A soft front will allow more change in toe than a stiff rear. But you are right in another way, there'll be more weight transfer to the rear outer wheel caushing the tread to distort a bit more. I read on Planetsoarer.com that someone had poly bushings in the front and worn out bushings in the back. The person's car would fishtail pronouncedly.
bentleymp2
02-12-16 11:51 AM
