GS on Espelir springs on 255 35 20 size tire?
From the Eibach website:
"When Eibach suspension springs are fitted, will the car sit at the correct ride height or will it need time to settle? Index
All Eibach suspension coils are pre-set to eliminate settling and increase life expectancy. Some minimal settling may occur as the new spring mates up to an existing rubber suspension isolator, this is normal, but is not the same as a poorly produced spring which may take a set and effect the ride height, handling and alignment of the vehicle."
