sc300 offset questions on 18's
I've been researching wheels for my sc300, but not sure on offsets I want. I want my wheels to be super flush, with no sunken in look. I'm actually wanting the wheels to sit out maybe a half inch to an inch, so I can use negative camber to fit them under the fenders. I don't mInd rolling my fenders either. here are the offets i have found..
18X8 5-114.3 30mm
18X9 5-114.3 15mm
18X9 5-114.3 38mm
i wouldn't mind going with 9's all the way around, as long as theyre flush. Heres a pic of my s14 with super flush wheels that needed negative camber to fit. I'm looking for something just like this.
Also, I didn't know what the offset on my wheels for the 240 were, since they didn't say and I bought them used off a 95 mustang GT. All I know is that they were 17X9.5 in the rear
18X8 5-114.3 30mm
18X9 5-114.3 15mm
18X9 5-114.3 38mm
30mm will give you what youre looking for.
15mm will stick out just too much.
38mm will fit perfectly inside the fenderwell.
Here's a pic of my car with 18x9 +22 offset.
Originally posted by grego2
No, the rim is too wide or no the offset won't work?
I see your running only a 9", is that cuz you'll hit the shock and spring?
Im running a 9" rim on the rear because these rims were off my MR2. With a 255/35 tire, I did not have to shave anything. I will be upgrading to a 19x10 as soon as I settle some debts.
Here is some helpful info.
https://www.clublexus.com/forums/sho...hreadid=113640
Mortgage Slave
and they fit fine. My tires are 255/40/18f 265/35/18r
Do you guys think wheels this size would fit good on a 93 SC300??
Bolt pattern : 5 x 114.3
Size : 18 x 8.5(front) & 18 x 9.5(rear)
Offset : 32mm(front) & 35mm(rear)
Lip size : 1" (front) & 2" (rear)
