review of tein HA, Flex, and CS coilvers on GS400
Old 04-29-04, 05:44 PM
  #76
Received 2,456 Likes on 1,610 Posts
Originally posted by rominl
and as long as you get the right offset on the 17s or 18s, you won't have any problem
Um, Henry, what has rim offsets got to do with Teins and EDFC?!
Old 04-29-04, 10:20 PM
  #77
rominl
exclusive matchup
rominl's Avatar
Cadd was asking whether 17s or 18s have problem, so i was saying if the offset is right then even lower won't rub
Old 05-04-04, 10:55 AM
  #78
Cadd
Cadd's Avatar
Uneven tire wear question for you guys with the Teins.
I will probably go with stock 17s for now, but will eventually go with 18s. Now if I'm going drop the car about an 1" or 1.25", will these Tein setups cause uneven tire wear?
Old 05-04-04, 12:47 PM
  #79
rominl
exclusive matchup
rominl's Avatar
uneven tire wear is from bad alignment. with 1" drop i THINK the car can still be within spec, if aligned correctly
Old 05-05-04, 10:04 PM
  #80
Wald GS
O.C. Lucky Strike Fanatic
Wald GS's Avatar
How do you adjust the height on the tein cs? Do you need 2 wrenches or what?
thanks
Old 05-05-04, 10:18 PM
  #81
rominl
exclusive matchup
rominl's Avatar
thanks
the tein cs comes with the two wrenches you need to use already
Old 05-06-04, 07:00 AM
  #82
johnee78
johnee78's Avatar
Just back up what rominl said, I have my car lowered with eibachs and my alignment was brought back within specs..I guess you have to find a shop that specializes in lowered cars..
Old 05-06-04, 12:38 PM
  #83
rominl
exclusive matchup
rominl's Avatar
thanks for the info!
Old 05-13-04, 08:27 AM
  #84
varcity64
varcity64's Avatar
ok, im a little confused... doesnt the edfc control the height of the car ??
Old 05-13-04, 08:37 AM
  #85
kidcapp
kidcapp's Avatar
no the edfc only controls the stiffness of the ride so you can make it softer or stiffer not the height
Old 05-16-04, 12:47 PM
  #86
RanGer498
RanGer498's Avatar
Default QUESTIONS and ANSWERES
My questionS(it might have be answered but i think i missed it)
im 99% sure now im going with the CS units but still looking at the flex...
ok some questions
1.can the TRD front strut bar be used with the CS or flex units ?
2.if the trd strut bar can be used can it be used if you also go with the EDFC Kit ?
3.if the trd stru bar does not work what strut bar works ?
4.willi really need a strut bar any longer ?
5.whats the chapest price you found it from and where?
or some answeres
1.Click here to view installation information.
2.Click here to view install manual.
Click www.tein.com for more information about this product.
info on the units
Tein Coil Overs
FLEX w/ Pillowball Upper Mounts
Contents of damper kit
Adjustable shock absorber x4
Main spring x4
Lower spring Seat x4
Spring Seat lock x12
Bump rubber x4
Dust cover x4
Hook spanner x2
Instruction manual
*Rr-H.A.S. = Height Adjustment System
*Strut suspension comes with upper spring seat.
Adjustable length and twin tube shell case. Special setting for sporty driving and ride confort. You can set your vehicle to meet all situations!
Tein Coil Overs
CS w/ Rubber Upper Mount
(KIT Includes)
Shockabsorber/4
Spring/4
Lower Spring Seat/4
Spring Seat Lock/4
Thrust Washer/4
Bump Rubber/4
Dust Boot/4
Rubber Upper Mount/4
Height Gauge
Install Manual
Damping Force Adjust Tool
Hook Spaner/2
Comfort-Providing Shock Absorber
*Upgraded shell case by 130% and lightening 20 compared to the genuine model
*Compleated spring and upper mount with absorber for reduced instllation time
*For you seeking higher quality of "comfort".
*Adopted mono-tube type to realize Heightening road holding
*Designed a hardness rubber upper mount for noise proofing
*Created driving pleasure with comfort.Realizing driving stability
Old 05-16-04, 10:27 PM
  #87
Neo
The One
Neo's Avatar
Default Re: QUESTIONS and ANSWERES
1. Yes. rominl has this setup.
2. No.
3. RMM will fit EDFC on Flex and CS. UGO will fit on CS.
4. Your call. Every piece contributes is some ways.
5. TMEngineering or Carson. Call them for pricing. Should be around 1300 for coilovers and low 300s for EDFC.
Old 05-17-04, 02:35 PM
  #88
Looks like an RVM strut bar should work with EDFC and Flex or any Teins. They're WAY cheaper than the RMM strut bar which I got. I could find an RVM one at the time.
Old 05-17-04, 07:03 PM
  #89
RanGer498
RanGer498's Avatar
RVM strut bar any pics of this item?
Old 05-18-04, 05:26 PM
  #90
rominl
exclusive matchup
rominl's Avatar
to clear up, yes the flex can accommandate the trd stb, but very tight spacing
Quick Reply: review of tein HA, Flex, and CS coilvers on GS400
