review of tein HA, Flex, and CS coilvers on GS400
#106
Well, after a visit to SRT in Maryland, Mo has convinced me that the Tein Flex is quite soft when at the softest setting (almost like stock), and rock-solid at the hardest setting.
I am leaning towards the Tein Flex now, since it gives you the widest range of setting. The CS is still an option though, since it's soft setting seems to be JUST like stock. Very soft. I like having that option too.
#107
just like my cs. it's in the middle settings now, it's good. if i make it too soft, it starts to get a bit bouncy too
#108
Originally posted by rominl
well, keep in mind, with teh flex, you probably don't wanna go too soft. both neo and i had the experience where with flex, if set to full soft, the car became too bouncy and felt weird. my guess is the flex still performs the best at certain range of stiffness, say around the middle. if you make it full soft, it's soft, but it bounces.
I need a reference point when you say "bouncy".
#109
The One
Rom, when you say "bouncy", do you mean bouncier than even the stock suspension?
There was a section of freeway where I used to work where I tested the float. I don't work there anymore and it is about 30 minutes away so I don't get to do these tests anymore. I'll have to find a new place closer to home for testing.
#110
The One
I know it is a hard call and it won't be as easy to tell right away. I loved the handling of the Flex and at first did not find it to be that stiff. As I lived with it over months, the bumpiness started to annoy me more and more. Add to the fact that my wife hated to be in the car and I knew I had to do something. Your situation may be totally different. I am not trying to sway you from one or the other. They are both great products but they are for people with different goals. Unfortunately, unless you want to spend $ and live with both for awhile, you'll just have to do what you are doing now to gather data and just bite the bullet.
#111
Kevin, your best bet is to find local owners of GS cars that have Flex or CS and feel for yourself. There must be owners of those around you.
As Neo and rominl say, the Flex and CS have pros and cons. The rubber mounts and softer spring rates of the CS will be more comfortable but still considerably more capable than stock, while the Flex have the metal 'pillow' mounts which are noisier over bumps (although not objectionably to me at all) and slightly stiffer spring rates. I'd be surprised if the dampers on either are much different. And with EDFC, both provide a range of damper stiffness.
I honestly think I would have been very happy with either setup. Go for it.
#112
EV ftw!!!
I don't find the Flex bouncy at its softest settings at all. The roads here are pretty bad especially in the city. The highways are pretty good and smooth. I have my Flex set to 15/16 as my daily driver setting and I find it very comfortable and not bouncy at all. In fact I tend to have it at that setting about 90% of the time.
Just like Bitkahuna said, you will not go wrong with either the Flex or CS. Just do it!!
#113
Here's the deal:
It's going to be a daily driver. I need maximum, silent, non-floaty comfort when called for, and then I want it to handle on rails (or as close to it) when asked.
I live in an area where I will eventually go over LOTS of bumps. LOTS. Some with potholes. I am concerned mostly with the "crashing" over bumps. When I want comfort, I want it to glide over the bumps, as best as 20s can anyway. LOL I'd prefer not to have it float like a Caddy if I can avoid it, but I DO want it quite soft when I dial that setting up. Is that even possible riding on 20's? I mean really, am I just asking too much. My Millenia with 18s and Eibach springs was unbearable in the city. Are 20's going to make it unbearable no matter which Tein I get?
I will ask for a ride in Mo's Lex though. I need some test data. I'll ask him who has the Tein CS in my area too.
Comfort is best for me, really. The lowering of the car, and then the stiffening of the shock through the module should give me all I need. I don't need go-kart handling.
Yeah, I have swayed back, I'll tell Mo I want the CS. LOL
Thanks ALL OF YOU for your input. Any more is appreciated.
I am not buying the Tein for about 1 month though, because the rims will come first. So, I have some time to get some more opinions and to get a test ride from Mo and others.
I am buying the Lexus because I want a luxury car with some azz, I am not buying it to be a total sports car, or else I'd buy a SPORTS CAR. LOL
Hmmmm....
I want the quietest, smoothest, most comfortable, non-floaty suspension I can get. It sounds like I want the CS.
It sounds like I am a flip-flopper. I am. I guess running for president is out.
Hmmmm....
#114
Does your Flex make any noise, Hameed? I want the suspension to be as silent as possible.
15/16 is almost as soft as it gets, I suppose, huh? And you have potholes too where you live? I live in DC. We have some whoppers.
What size are your rims, Hameed? Just curious.
#116
The One
Definitely get test rides if you can.
#117
Originally posted by Neo
I notice there is not a mention of gokart handling in there
so I think you want CS too. It sounds like you already know but there are limits to how soft a ride can be with 20s, even with 18s. You just have less rubber than the standard stock 16s. When you hit a big sharp bump, you will definitely feel it as it is not dampened by the rubber. There is only so much a shock absorber will take.
When I want it to handle as close to a go-kart as possible, I want that too, but it needn't be JUST like a go-kart. I just want it to be firm, with very little body roll, when called upon.
CS will probably do me.
#118
well, i talked to neo alot when we were looking for different coilovrs, and thus why we came to the conclusion. i didn't really know what the floating feel was until i drove neo's car with the cs (when i had the flex), and then i got the cs as well. immediately i figured what it's like when the flex is at the softest but floating, whereas the cs is just as soft but yet "firm". yeah i know, it's hard to describe, but that's the best i can put it into
kevin, i think your best bet, just ask around for CL members and take a quick ride in their cars. you will know fors ure. it's not small money, so spend wise.
plus imho, with the cs, although the ride is softer, i don't really lose much handling. yes the car roll a tad more than the flex on sharp hard turns, but it's still pretty much the same speed
#119
KevinGS - sorry to say it, but if you want 20s, a silent ride, great over pot holes, yet want it to ride on rails on demand, you're dreaming.
From all your comments, I say you should get the CS since comfort and quiet over bad roads seems a strongly recurring theme.
#120
What will the L-tuned steering ECU do for me? Will this work on Aristo V300?
I like the sound of the Tein RA + EDFC, it concerns me the strut-brace might not fit.
Comments?
Comments?
