Loose steering 03 gs300
Old 05-03-04 | 09:56 PM
dirk's Avatar
dirk
Default Loose steering 03 gs300
We have a 03 GWe have a 03 GS 300. At highway speed it has a mind of it own. It seems way to sensitive. Bought the car new, complained about it and told it was normal! The even checked 4 wheel alignment and said everything was OK. It checks out normal. I say B.S. We had a 98 Gs 300 that drove fine. My wife and I are sure that a car in this price range shouldn’t make us feel uncomfortable driving at highway speeds. My 95 pathfinder with 145,000 mile drives better. Any one have this problem with their Lexus? What was the fix!
PS Yes I did the search thing, and from what I read back to (2 year ago ) leans towards the ECU
What do you think
Thanks
Unhappy Lexus Owner
Dirk
Old 05-04-04 | 09:20 AM
ChuH's Avatar
ChuH
Have you check the PSI on the tires? Too much air pressure will cause sensitive steering. What size of tires and rims do you have?
Chu...
Old 05-04-04 | 05:48 PM
dirk's Avatar
dirk
everything is stock! psi is at 32
Dirk
Old 05-04-04 | 06:25 PM
PHML's Avatar
PHML
Master Thread Closer!!
Maybe its time to upgrade to LTuned ECU....that should stiffen up the steering wheel. Contact Steve at Carson Toyota.
Pete
Old 05-04-04 | 08:54 PM
HKGS300's Avatar
HKGS300
what rim/tire sizes do you currently have, and what was on your previous GS?
Putting bigger rims/wider, lower-profile tires will significantly improve the steering feel.
What mods were on your previous GS?
Also, did you try-out a similar 03 GS300, and how was the steering on that car?
sclexus300
01-05-12 08:56 AM
newyorker
Suspension and Brakes
03-24-03 05:06 PM
advsystems
12-13-02 02:22 PM
GS300.ru
09-22-01 02:55 PM
johnb
07-17-01 09:12 AM
