Supra Front Brake Upgrade
Old 05-15-04, 05:22 PM
rodel
rodel's Avatar
Default Supra Front Brake Upgrade
I've done searches, but have not come up with a clear answer. I want to make sure that the braided brake lines that I get are neither to short nor too long.
For those of you that have done the upgrade, which braided hose did you use? Which manufactuer? Did you use the application for a Supra or GS?
Old 05-15-04, 08:03 PM
DaveGS4
Forum Administrator
Administrator
DaveGS4's Avatar
Received 2,330 Likes on 1,418 Posts
I believe mine are Goodrich. I honestly don't know what fittment they are, Steve Ganz just sent me the right ones with the kit.
Old 05-18-04, 05:25 PM
rominl
exclusive matchup
Senior Moderator
rominl's Avatar
yup, another vote for goodridge. steve ganz can get you the right one no problem
Old 05-19-04, 07:41 AM
jucee187
jucee187's Avatar
how much does the Supra brake upgrade cost.. and is it a direct bolt on replacement or is any modification needed?
Old 05-19-04, 01:10 PM
rominl
exclusive matchup
Senior Moderator
rominl's Avatar
everything together about 1k? forgot what price i got last time
and it's direct bolt on
Old 05-19-04, 11:26 PM
DVSG3
DVSG3's Avatar
What are the advantages to the Supra brakes? Are they lighter? Stronger? I have never had fancy brakes. They look cool. But...?
Old 05-20-04, 07:35 AM
rominl
exclusive matchup
Senior Moderator
rominl's Avatar
4 pistons vs stock 2. weight about the same. size is a bit bigger i believe?
Old 05-20-04, 09:36 AM
CinFulxgs
CinFulxgs's Avatar
Does upgrading to the Supra setup improve braking? I know going to something like StopTech does but I was under the impression the the GS400 had world class braking already if I remember my article readings there was very little with a shorter 60-0 stopping distance....
Old 05-20-04, 01:13 PM
rominl
exclusive matchup
Senior Moderator
rominl's Avatar
you are correct, even with big brakes you don't expect to get much shorter braking distance. but it's the brake fades, and the braking feel that are improved. with the stock brakes, after a 350 miles trip, my brakes were defintiely fading. plus the brakes felt so soft... after my new brakes, after the run it's still like new. and the ss line makes the braking feel much more solid
Old 05-20-04, 08:51 PM
lexlyf
lexlyf's Avatar
Originally posted by CinFulxGS4
...I was under the impression the the GS400 had world class braking already....
Yes, I'll take "feels like a sponge" for $200 Alex!
Old 05-20-04, 09:48 PM
DVSG3
DVSG3's Avatar
Old 05-20-04, 09:59 PM
lexlyf
lexlyf's Avatar
It was a playful "stab." No harm intended.
Old 05-20-04, 11:24 PM
DVSG3
DVSG3's Avatar
Sorry, I meant . I was laughing.
Old 05-21-04, 08:58 PM
rodel
rodel's Avatar
I've been searching, with no luck. I cannot find a manufacturer that makes cross drilled front rotors for the stock MKIV turbo. Could anyone help?
Old 05-21-04, 09:05 PM
lexlyf
lexlyf's Avatar
Hold on. I'm doing a quick Google search.
Be right back!
Quick Reply: Supra Front Brake Upgrade
