which brand SS brake line do you like???
is there any one brand of brake line yu would consider supieror??
I seached but dind't come up with anything.
I know the Russels Stailess steal braided breke lines DONT have a teflon intieror
(think it's just plain rubber)
DUnno if that is good or bad.
I see other companies marketing braided Teflon lines.........
any suggestions?
Thanks
Ken
any suggestions?
Thanks
Ken
I don't think the brand really matters. In fact braided lines themselves only have a minor effect over stock lines under extreme braking situations. For us they are more of a dressing...
ps forgot to mention
I'm upgrading to TT front brakes
so I figures since the brake are gonna be bleed, might as well change the lines (which are really sponggy now at 64k miles)
hey ken, most people here use the goodrich lines, they are the same as the trd lines except with a different name. they are also a bit cheaper. i have them on my car and the pedal feels good when braking hard.
Originally posted by TGRich
As another part to the question, you may want to ask which brands require no modifications at the flange.
goodridge catalog (http://www.goodridge.net/usa/pdf/aut...top_app_us.pdf) shows kits only available for 93 and up, but not 92 - has anybody installed on a 92??
make sure whatever you get has a coating on the OUTSIDE as well to prevent dirt and debris from working it's way into the steel braid and abrading the line inside...
as has already been mentioned, in terms of performance, don't expect shorter stopping distances from any of the above - you will only get a marginally better brake feel, and even then, most of that will be attributed to the fact that the stuff is new vs. your old lines, and you have new, fresh fluid...
I bought magnum brake lines off ebay, much cheaper than goodridge and others, but the exact same product. It does have an outer coating also. Brackets mounted fine!
Also... I noticed a marginal improvement in the brake pedal feel. I love them. And unlike brake pads, these should last a LOT longer.
