LS 4-piston Brake setup for my SC4
Old 10-08-12, 08:08 PM
  #286
nemean
nemean's Avatar
WOOT! Walked outside all scared as hell that the LS400 brakes I bought today at a junkyard wouldn't clear... 3.6 inches of clearance from rotor to inner rim. :3 YAY!
Old 01-06-13, 09:23 AM
  #287
suprahero
suprahero's Avatar
I'll be doing this today. I couldn't find any ls400 dust shields locally so I'll just remove my sc300 shields.
Hopefully my install goes smoothly without any bodily injury...........lol
Old 01-06-13, 04:42 PM
  #288
suprahero
suprahero's Avatar
Out with the old.
In with the new.
Here it is with the brakes bled and the lug nuts tightened. All that's left is a test drive.
Old 01-06-13, 06:03 PM
  #289
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
Man. I love those wheels. Brakes looks great but the rotors look straight pimp.
Old 02-28-13, 07:37 AM
  #290
SliC300
SliC300's Avatar
Couldnt help but notice that no one in this entire post mentions what brake lines they upgraded to, and whether or not they got the lines for the Sc or the Ls... so, any takers on that question? What brand of SS lines did you buy and for what model?
Old 03-14-13, 10:23 AM
  #291
mattjk
mattjk's Avatar
Centric 141.44170 Semi-loaded Brake Caliper - Natural, Semi-loaded, OE replacement
Part #: CE141.44170 | Mfr #: 141.44170
In Stock
$51.70
Are these good replacement calipers?
Old 03-14-13, 12:34 PM
  #292
xspsi6
xspsi6's Avatar
Sc lines work as will as all mkiv supra lines.
Old 04-11-13, 05:59 PM
  #293
myLEXsc400
myLEXsc400's Avatar
so does this mean that the ls400 lines will not work?
Old 04-11-13, 09:33 PM
  #294
stevechumo
stevechumo's Avatar
The LS caliper is made of alunimum, so it doesn't get hot. I drove my car for awhile and it doesn't get warm. Therefore, it can be painted with regular paint and then top off with clear coat to prevent scratch. There's no need to use caliper paint, which is expensive and limited in color.
Old 05-17-16, 01:21 AM
  #295
Zerodrag
Zerodrag's Avatar
Read through the whole thread and didn't see an answer to this question...
Will the factory SC spare clear the LS setup with a 15mm spacer? Need to know if I will need to look for a new replacement spare. I know it was mentioned that a factory 17" GS wheel will with that spacer.
Old 05-17-16, 07:39 AM
  #296
CatManD3W
CatManD3W's Avatar
I highly doubt the 16" spare will fit
Old 05-17-16, 01:01 PM
  #297
Zerodrag
Zerodrag's Avatar
I was hoping it would (with spacer) as I had been told that the 95 LS factory wheels were also 16".
Old 05-21-16, 09:09 AM
  #298
Blkexcoupe
Blkexcoupe's Avatar
The LS does use a 16" wheel, but just because the outside diameter of a rim is the same doesn't make the inside diameter the same. The stock SC 16" 5 spoke clears with a spacer, but it could potentially hit the wheel weights on the caliper.
On a steel wheel the inside diameter gets smaller where they weld the face to the outer barrel, so I imagine that can create clearance issues. I've never tried first hand to see if the steel rim fits, but I don't think it will either.
JOHNBROWN
Florida Lexus Club
10-29-20 09:43 AM
jvsc300
Suspension and Brakes
16
02-09-09 04:38 PM
GoldGS3
08-03-07 08:42 AM
jgscott
11-13-06 01:02 PM
sourcemine
SC400 / 300 Classifieds
19
01-11-06 04:38 PM
Quick Reply: LS 4-piston Brake setup for my SC4
